Question about Nokia 3120 Cellular Phone
My noki 3100 does not ring when someone calls
My nokia 3100 is not ringing when someone calls. I have tried maintaining all the settings, but still it is of no help! if anybody could tell me an appropriate solution.
Thanks.
  • 63 Answers
Might speaker got damaged
Posted on Apr 25, 2010
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
I have the new nokie 6700 slide and the sound just stopped working, it hasnt been wet or anything it just stopped working i cant even hear it ring. please help
Make sure that the incoming call alert (under profile settings) is "NOT OFF"...
Make sure the profile is not in silent mode...
If everything is ok, then probably it may be the ringer might have gone bad... You can take it back to any Nokia care and ask them to check the status of ringer...
Feb 25, 2011 | Nokia 6700 Classic Cell Phone
Nokia 1110i incoming call is not ringing
Your Phone Ringer Default So Please change Ringer And Problem will solved .
thanks.
Jul 20, 2010 | Nokia 1110 Cellular Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
MY phone 3100
no need to worried ................
....................your mobile speaker is not working.....
contact nearest service centre.......................
Feb 03, 2009 | Nokia 3100
My Nokia 6085 rings two-three and then just disconnects.
try to change the ringtone or ring style. options>set profile>[whatever profile you are using].customize.
Jan 12, 2009 | Nokia 6085 Cellular Phone
I want my N73 to ring for longer than 2 rings
Hi
Set a FULL SONG from your archive as RING TONE. This will play longer time to remind you that someone is calling.
Thanks.
Supriyo DG
Jun 12, 2008 | Nokia N73 Cellular Phone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Let me know if you need further assistance
Jan 15, 2008 | Nokia 7250i
Nokia 3120 Cellular Phone Logo
204 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
