Question about Viking DFUD142D Built-in Dishwasher
How to fix beeping on viking dishwasher model DFUD142D, its a new apartment and under the counter dishwasher.
Stuck in drain cycle
Hello Vicki. If the drain pump sounds like it is running and will not shut off, you are on "flood mode" There is standing water in the bas pan of the dishwasher. sometimes water can get down there due to an overfill, or not draining completely between cycles. You can either wait for 2 or 3 days and the water will evaporate and should run normally. You can remove the bottom access panels and either vacuum out of dry the water (REMOVE POWER FIRST !) . If it does not clear on its own or if removing the water manually does not work, then the float switch will need to be replaced that activates the flood mode. There is a small possibility you have a bad control .
Apr 09, 2014 | Viking DFUD142D Built-in Dishwasher
I have a Viking VSM700 mixer that worked one day and was put under the counter. Next time it was brought out, it did nothing. No smoke, no noice, nothing. Any ideas?
On mine, one of the two brushes was NOT advancing to hit the motor armature as it wore. Had no power. Had to take unit apart to get to motor. We spread the metal brush holder slightly with a screwdriver and allowed the brush to slide so it can make contact with the armature. Motor now works fine. Shame on the Viking Company for dropping the ball on this product!!!
Jan 17, 2014 | Viking VSM700 Stand Mixer
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
Aug 10, 2012 | Viking DFUD142 Built-in Dishwasher
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Viking Dishwasher
Probable cause is either a bad fill valve, common with these, or just some debris in the fill valve inlet screen, also common. If you are handy you can take apart the fill valve and check the screen but often one needs to replace the whole valve, about an $80 part + labor. Double check your valve under the sink and make sure it is on completely.
Apr 30, 2008 | Viking 24 in. Professional Series VUD040...
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Viking DFUD142D Built-in Dishwasher Logo
217 people viewed this question
Top Viking Dishwashers Experts
Mike
ray gallant
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
