Question about Frigidaire Dishwashers
Frigidaire dishwasher FDB4050LHS1 Gor about 6 mos ago. Worked great until last week. Now it shows PF just about every day. It will reset itself after a while but shuts down completely first. Happens when wshing and also when not being used.
Delay timer will not turn off
Posted on Jul 16, 2011
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
When I close the door it flashes Pf when I push the button normal everything goes off. -It was worked on a couple months ago vent was bad but module board was also changed out. I unplugged it overnigh
PF is a power failure of some sort. Check your wiring to the dishwasher for loose connections. Opening and closing the door should have reset the error code, so you might also take a look at your door switch/latch to make sure it's working.
Good luck and let me know if I can be of further assistance to you.
Oct 24, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher pf dims and stops
Hello Colton Rawlings, thank you for your post!
Based off what you are describing "PF" stands for power failure on a Frigidaire dishwasher. If the lights are dimming then your appliance flashes "PF" it could possibly be an issue within your panel or your appliance is not getting enough power to it. I would recommend contacting a professional to come and diagnose your appliance properly. I hope this is helpful. -Matt
Sep 06, 2014 | Frigidaire Dishwashers
START BUTTON WON'T WORK
Unplug it for ten or so minutes and that might reset it..
Dec 12, 2013 | Frigidaire FPHD2491KF Dishwasher
Frigidaire dishwasher model number FDB4050LHS1 making a loud squealing noise
Usually this is the drying time of the cycle. I would have a professional look into the blower assembly and heating elements of the unit.
Aug 25, 2012 | Dishwashers
Pf code came on and then went to er code reset power and pf code comes up then starts showing 37-36
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
,./;''l
Jun 18, 2010 | Frigidaire 24 in. PLD2560LCC Energy...
I have a built in Kitchen Aid Dishwasher and my rinse aid dispenser has been full for weeks
since it only uses a few drops each cycle it it quite possible it looks full
a full jet dry resivoir, will last about 6 mos
Oct 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My diswasher worked great until last week. It started to clean less and less so I cleaned the filter and checked to see if there was any food in the bottom built up. Now it won't spray water at all...HELP
Had a very similar problem myself with my frigidaire. The spinners, which are removable, were completely clogged with calcium. Soaked them in vinager overnight and then poked each hole/jet individually with a paperclip. Worked like a charm, hope it does the same for you.
Aug 08, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Feb 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwashers Logo
202 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
