Error Number : 1403 Print head problem. Remove the print head and then re-install it. If this message appears again, the print head may be faulty. Replace the print head with the new one. what is this?
It is likely that the print-head temperature sensor is detecting an over heat. If that is the case, start thinking about a replacement machine as the printheads are expensive to replace.
The print head is not installed [1401], or it is not properly installed (Print head temperature sensor error [1403] / Faulty EEPROM data of the print head [1405]).
If you wish to get more details about this; visit the site linked here; after an hour.
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
1401/E05
Description: The print head is not installed or has not been properly installed.
1403
Description: A print head temperature sensor error has occurred.
hello this error means that the EEPROM data of the print head is faulty so is a problem with the print head, Install the print head properly,and close the access cover. Or, with the print head installed, turn the printer off and on, i hope it will help And please check the below link to get the service manual for ip4000 it will be helpful: http://goo.gl/Edjmh
This error is the print head is not installed [1401], or it is not properly installed (Print head temperature sensor error [1403] / Faulty EEPROM data of the print head [1405]).
5 times
The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405].
Install the print head properly, and close the access cover.
Or, with the print head installed, turn the printer off and on.
This might help
