Question about Frigidaire GLTF1240A Front Load Washer
LOOSE DRUM, BANGING - Frigidaire GLTF1240A Front Load Washer
  • Frigidaire Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 26, 2010
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Drum is banging during spin cycle.
Washer Problems Washer noise when spinning
heatman101
Posted on May 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: dryer banging
Check the vibration damper rods. It is detecting an uneven load and stopping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have just moved my asks w 6551 to a new house and now it's making a banging sound when the drum turns. Is this serious?
Those machines come with shipping bolts that hold the drum to the frame when it is shipped. This ensures that nothing gets slammed around when it is moved. Without those in place, there is a chance that the shock absorbers and springs that align the drum when it is on CAN COME loose and then you have a banging noise when the drum spins.
Oct 22, 2017 | Washing Machines
Washer drum loose and banging
There are springs that support the drum, open it up and check them out.l
Nov 25, 2013 | Washing Machines
Beko 510w
the beko washer sometimes the concrete balance blocks come loose and cause a banging noise unplug and take the top off check the concrete block on the top off the outer drum to see if it moves about tighten it up if loose then check the one down the front to see if louse
Sep 20, 2012 | Washing Machines
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Soumds like something is loose and banging. Nothing is lose and banging in the drum where the clothes are
if it is new you may need to remove the shipping rods that keep the drum secure for shipping look in the back there should be two of them if its not new I don;t know the answer
Jan 20, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Frigidaire GLTF1240A Front Load Washer Logo
399 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
