Tomtom ONE 3RD EDITION GPS Receiver Logo
Posted on Apr 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i find resurants on my tomtom - Tomtom ONE 3RD EDITION GPS Receiver
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Apr 27, 2010
Anonymous
Expert
Level 2:
Answers
218
Questions
Helped
62132
Points
610
Turn on the GPS and tap on the main screen. Tap on : Navigate to.. Tap on : Point of Interest Tap on: POI near you. Tap on: Restaurant. A list of restaurants will show up. tap on the one, you would like to try. Tap on select. tap fastest route (optional) tap done. on to route screen tap done once more. Tap continue if any warning appear.
I have a tomtom one n14644 I would like to update it and im not sure how
The usual way to update your TomTom GPS is using the TomTom HOME software that you download and installed on your computer/laptop. Then set up your TomTom account (using the TomTom HOME application) and registered your TomTom device (in that account) on the TomTom webiste
After that, connect your TomTom device to your computer/laptop (using the USB cable). Turn on the TomTom device, and touch the YES icon (on your TomTom screen) if it asks whether you'd like to connect to the computer.
You should be able to see the updates available for your TomTom device (on the TomTom HOME application). Select the updates you want and (download and) install them.
Recently TomTom has stopped providing software/map updates and/or support for certain (older) models of their TomTom GPS. If you see such a notice when you register your TomTom device, your option is to get a newer GPS model (you may even get an offer on the TomTom HOME screen), or you can continue to use your device without updating the software and/or maps until it becomes unhelpful, unreliable, etc.
Jul 03, 2019 • Tomtom GPS
2answers
Im trying to update my tomtom start.but i cant get it to dwnld on my laptop.
I'm assuming you have
- the TomTom HOME (or MyDrive Connect) software installed on your computer/laptop.
- you have a TomTom account and have registered your TomTom device (in that account) on the TomTom webiste
- you are able to successfully plug your TomTom device to your computer/laptop, e.g. using the USB (cable or cradle)
- you can log into your TomTom account and have the TomTom software (HOME or MyDrive Connect) recognize your device (as being connected)
- you see the list of software/data/map updates available for your device
... and you still can't download the software/data/maps ... ? to update your TomTom device ... ?
Have you been able to get any help/support from the TomTom website ? www.tomtom.com to do this ?
Apr 16, 2018 • Tomtom GPS
1helpful
2answers
How do i update my Tomtom 3RD Edition (1GB) GPS Systems for free i would appreciate it if you have an answer thanks.
Hi, I was having trouble too and have found the manual for the 3rd edition online
http://download.tomtom.com/open/manuals/one3rd/refman/TomTom-ONEv3-en-GB.pdf
I'm following these instructions:
Installing TomTom HOME
Install TomTom HOME on your computer in the following way.
  • Connect your computer to the Internet and then connect your TomTom ONE to your computer using the USB cable.
  • A pop-up window appears. Select Run TomTom HOME. Click OK and follow the on-screen instructions.
  • If the pop-up window does not appear, browse to the TomTom device on your computer and run the file named Install TomTom HOME.
  • TomTom HOME is also available for download from the TomTom website.
  • For more information visit www.tomtom.com/home
  • Once installed, TomTom HOME will start automatically whenever you connectyour TomTom to your computer.
Hope this helps, Lynsey
I have a casio sea pathfinder spf-51 and i opened the case to see if i could change the battery myself.Unfortunately one of the 3 springs fell out and i cant see where it should go.Can anyone help me with...
mcdevito75 here, My best advise is to see how the other 2 springs are situated in the watch, then simply follow suite with the 3rd spring. BE VERY CAREFULL THOUGH AS< ANY OR TOO MUCH RESURE ON THE CASIO DISPLAY WILL RUIN IT. If you can"t find the spot for this spring, look for a small watch repair shop in your area for help, it"s better than ruinning your watch.
4helpful
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Tomtom 920 bluetooth disabled
repair both ...start fresh from start.....do a hard restart on the TomTom...this is located on the last menu of your tomtom...Factory reset...it will erase recent destinations and favorites....but it usually clears the tomtom....Now try to repair both the phone and the tomtom
My tomtom receiver is frozen on the start screen.
Connect your TomTom to the USB cable then turn on your TomTom in that order. Go to "My Computer" and open the drive that is your TomTom. Copy and paste your map folder to the desktop. Delete everything on your TomTom (don't format). After deleting everything on your TomTom. Open TomTom Home. TomTom Home will tell you, you need an application for your TomTom. Let TomTom Home load the application. You will probably have to do this at least 2 times to get the latest application for your device. After TomTom Home has loaded the latest application for your device closer TomTom Home and copy and paste your map back onto your TomTom. You should be ready to go after doing this. Make sure you do not skip a step when doing this.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
