Question about Honeywell Programmable Thermostat Heater
The fan will blow but not in heat mode. The gas heater sounds like it wants to work but there is no heat.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. The problem is probably with the ignition. Check the pilot if its a standing pilot or the hot surface ignitor if it has a HSI ignition If you ohm the hotsurface ignitor and it doesn't show resistance the HSI is shot. If its a standing pilot try lighting the pilot if it lites and doesn't stay lit then the thermocouple could be bad its the rod that sits in the pilot flame easily replaced with a universal replacement that can be found at most hardware stores.
Posted on Apr 25, 2010
Heater a/c control unit not working
what mode, heat or cold?
does fan blow?> no "? then replace the fan fuse.
fan blows on high? yes.
then if A/C ? wanted? why not say? then the green light glows
near A/C switch, does it? y/n
yes the does A/C compressor clutch close? and compressor shaft turn? y/n.?
or its heat you want? not stated.
so no heat, is a whole other list. ill try.
1: engine not hot, not 180f min. and holding (y/n)
2: cab fan dead.
3: heater core not hot, (feel the hose there both must be hot)
4: damper stuck closed blocking heater core.
Mar 25, 2014 | 1996 Geo Metro
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Jan 11, 2010 | Heating & Cooling
Fan blows but no heat/fan won,t shut on and off in the auto mode
Certain gas furnaces will default to high speed fan ON any time a high temp limit opens or the 24 volt transformer fails. Please respond to describe your make of furnace and if the fan runs only when your thermostat calls for heat or if that makes a difference.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
I get 4 blinks it say open limit switch what does that mean
Your induce fan motor senor is out. The little fan motor that take out the heat has a sensor that tells the furnace thats its working. Some time it get stuck. Try blowing and sucking into the tube. you should hear a click
www.fastacservice.com
Oct 16, 2009 | Goodman GMS90703BXA Heater
HEATER NOT WORKING IN 2001 LEXUS RX 300
you most likely have a bad airmix servo. this happens alot on these. they are expensive to replace too.
Sep 10, 2009 | 2001 Lexus RX 300
Heater not working when on Heat but working when on Fan
is there a venting fan, that may be faulty not sending power to heat
Aug 03, 2009 | Heating & Cooling
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
124 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
