Question about Kitchen Ranges
G.E.RANGE OVEN WHEN TURNED ON REACHES DESIRED TEMPERATURE STAYS ON FOR A SHORT WHILE THEN STARTS BEEPEEING, HOW DO I CORRECT IT?
  • Kitchen Ranges Master
  • 43,501 Answers
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 27, 2010
After oven reaches desired temperature, it has late ignition that turns off the pilot AND OVEN WILL NOT STAY ON.
Sounds like the pilot is mounted to far away from the burner. I have seen it happen before where the pilot has detached and the main burner will just keep pumping gas in until it hits the pilot flame and just flash flames and everything goes out.
Or it just could be a bad thermocouple that is going out all the time.
Mar 01, 2013 | Southbend S36D 36" 6 Burner Gas Range,...
Is there any way to turn off the beeps- starting oven, when it reachs set temp, changing temp
Hello g harrison - Unfortunately the range does not have an adjustable volume level or cannot be turned off. It is designed to advise you of when the oven is starting or reach desire temperature.
Nov 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool oven shuts off - Error Code F2
The "F2" error code for this oven means "one or more keys on the keypad are shorted". The correction is to replace the control panel because keypad does not come separate.
The part is not available but if you call the number of that supplier I'm sure they may find the part for you.
Here is the info.
Nov 09, 2012 | Kitchen Ranges
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Convection oven fan rattles when it is starting up after the oven has reached its desired temperature. The fan motor has been replaced once but it didn't fix the problem.
Check the shield in front ok the fan. It may have become distorted with heat and is now touching on the fan when the oven reaches temperature.
Nov 22, 2009 | GE Cafe CGS980S Kitchen Range
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
GE oven
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
