Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint refigerator not making ice after i defrosted it
  • rhubner929 Apr 25, 2010
    the condenser coils are very clean any other suggestons
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer. Your ice maker might not be making ice because of a defective defrost thermostat. Test your defrost thermostat to determine if it has malfunctioned. If you thermostat is good then you will need to replace your main board. Click on the link below to view
http://forum.appliancepartspros.com/refrigerator-freezer-repair/9277-hotpoint-refrigerator-not-dispensing-water-ice.html
Posted on Apr 25, 2010
    Brigadier General:
  • 3,917 Answers
The basic reason for the refrigerator not to remain cool is because of a dirty condenser coil.
Please check the steps you need to perform in the bellow posted articles . These are already tested with other customers with similar issues and has worked out.
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
and
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Refrigerator is not freezing or making ice its running but not cooling
u might have a defrost problem., defrost manually then kick it back on. if it starts frezzering and making ice then u need to change out your defrost timer, first and see., try that ok.
Feb 12, 2011 | Hotpoint HSS25GFP Side by Side...
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
Apr 22, 2010 | Refrigerators
The top of my refigerator is freezing in the back
Hi, the problem you are having is the defrost timer not going into defrost mode when the timer says to. They are normally located in the bottom back of the unit and will have a screw driver slot on it. It may be stuck in the off position. Turn it a click with a screwdriver and see if this starts the defrost mode and other problems. Is the evaporator fan in the freezer up and running? If not, this motor must be on. Keep me posted on this and we can get to the bottom of the problem.
Sincerely,
Shastalaker7
Mar 03, 2010 | Refrigerators
Refigerator will not saty cold but freezer works
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Solution for ''my side by side msd2556aew matag refigerator is not keeping the refrigerator cool It has ice build up by the fan in the freezer
your not going through defrost cycle. remove rear panel in freezer and defrost ice. need to verify defrost timer, defrost heater and defrost thermostat. these are the only parts that deal with defrost cycle.
Jun 22, 2009 | Refrigerators
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
How to defrost a refigerator
A simple way to defrost would be to take your perishables out of it and place them in a cooler. Then unplug the unit over night. It will be defrosted in the morning. Regarding the manual just google the name of the fridge. For example if it it an amana, search amana.com
Please rate my answer a fixya.
Mar 03, 2009 | Refrigerators
Freeze slite cool but refigerator is not cool at all
Sounds like a defrost system failure. This could be the freezer fan, heater, timer. You need an OHM meter.
You can manually defrost the freezer with a hair dryer that will get it working for a couple of days. Remember there is a lot of ice behind the freezer back wall, you can only see the tip of the iceburg.
Jan 23, 2009 | Maytag MZD2766GES Side by Side...
I REPLACED ICE MAKER UNIT BECAUSE REPAIR MAN TOLD ME THAT THE HUMMINING NOISE WAS DUE TO ICE MAKER BEING STUCK IN A CYCLE. AFTER REPLACEMENT THE NOISE IS STILL THERE. WHEN I SHUT THE ICE MAKER OFF NOISE...
theres ice in the fan propelar, if you see no ice blocking the propellers its the fan motor itself,if you unplug the fridge and stick something thin between the vents where you feel the air blowing thru and try turning the fan,gently and it spins smooth its the fan motor,if you dont wish to do this turn freezer off,open the door and let it defrost,then plug it in if buzz still there its the fan motor
Jul 08, 2008 | Hotpoint Refrigerators
HOTPOINT REFRIGERATOR RUNA ALL THE TIME COOLS POORLY
Yep, that is it. The heating element is open and/or the defrost timer is bogus. for parts go here. Search Over 2 1 Million Appliance Parts
Sep 09, 2017 | GE Hotpoint 21.8 Cu. Ft. Top-Freezer...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
