Question about Brother DCP 130C All-In-One InkJet Printer
It is not printing. It says: "Unit unable AP" And also the Blinking red "!" light.
  • 1 more comment
  • Raphael Josiah Apr 26, 2010
    This is the brother DCP-130C. The advice I got is for another printer.
    Ok. you are right. Unit unable AF. Ok. I've seen the switch on other printers before(larger copiers) but none on this one. Shouldnt I still be able to print if this is just a scanner problem?
    Thanks for giving me the best, accurate solution out there.
    President:
  • 1,194 Answers
Thanks for using Fixya.
There is no error like "Unit unable AP"
But there is an error "Init unable AF" and Blinking red "!" light.
I think this is your problem.
Error AF means that the scanner unit is malfunctioning.
This is a hardware fault and cannot be solved by an end user.
The scanner unit have to be replaced.
Else,
Sometimes these small machines have a lock to hold the scanner in place for shipping.
Check to see if you have one and be sure it is the unlocked position.
If you have one it is usually on the left side or under the scanner portion where the paper comes out.
I hope this may solve your problem.
Good Luck and have a nice day
Posted on Apr 26, 2010
  • Ranglo
    Ranglo Apr 26, 2010
    As you printer is All In One, If any of the device (scan, print,copy etc.) is faulty, it will not perform any operation until it has been resolved.
  • 369 Answers
When all the lights are flashing together, turn the printer power OFF, wait 5 seconds and then turn the printer power ON again. If the error continues, disconnect the interface cable from the back of the printer and use the following steps to reset the printer:
Turn off the printer. Press and hold down the Go button on the front of the printer, at the same time turn the printer power on. When the Toner light is on by itself, release the Go button. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
If the above steps does not help, you can use the link given below:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/000100/000070/faq000170_000.html?reg=as&c=au&lang=en&prod=hl5170dn_all&Cat=
Posted on Apr 25, 2010
Alternating red and white blinking light on earpiece for afterglow pl-6360 then shuts off. Unit should be fully charged. Help!
Alternating red and white LED colors indicates that it is not detecting an active bluetooth connection. Use the PS3 bluetooth settings to find and reconnect the signal.
Sep 29, 2013 | PDP Pelican PDP PL6360 Sony PS3 Bluetooth...
My Cisco aironet 1141N-ke9 showing red blinking continuously and stuck in that .Now only access via console.Can any one solve it
Sounds like the network connection to the AP is shot. Try a different cable, different port on the switch, or repower the device.
Aug 05, 2012 | Aironet Air-ap1141n-a-k9 Cisco 1140 Series...
Mx850 canon all in one. was working fine then the alarm light came on and screen shows error code 6A00??? have tired moving the ink cartrigde device, unplugged and pluged back in ... checked everywhere...
6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
Dec 31, 2010 | Canon PIXMA MX850 Multifunction Printer
Cant ge the print cartridges out of my Canon MP830
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. And also please use original Canon cartridges to solve your problem too. Thank you
May 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Says Check printer 6A00. Any ideas?
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
May 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error 6A00
May 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Oct 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
ML-2510 mono laser printer / samsung
the answer is on:
fixyourownprinter.com
May 09, 2008 | Samsung ML-2510 Laser Printer
Status light is red
Hi, Based on your post/description, the Siemens AP/Router is at fault. This could have been brought about by lightning, power surge, plain hardware failure or system/software error. The red status light - on indicates an error (on the firmware)(blinking during start-up or when firmware is being downloaded/updated); WAN light blinking green - data transmission to/from your ISP (it is also possible that the router is trying to download corrective software or firmware update). Suggest you let it run for sometime just in case it is really downloading/upgrading firmware. If full reset of the router doesn't correct the problem, you may have to replace the unit. Good luck and kind regards.
Aug 26, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Brother DCP 130C All-In-One InkJet Printer Logo
103 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
