Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
M 917258571 does it need tran fluid it won't pull up hill good
    Problem Solver:
  • 9 Answers
Most likely the drive belt is slipping. It either needs an adjustment { if this model has an adj.} or the belt needs replacing.
Posted on Apr 25, 2010
How do you check the transmission fluid on 1995 buick regal
Just pull the dipstick out for the trans while the engine is idleing in park.
Jul 24, 2012 | 1995 Buick Regal
TRANSMISSION
Check trans fluid. If not full put a lucas trans additive then top off with trans fluid. check for leaks.
Dec 20, 2011 | 2000 Pontiac Montana
05 f-250 super duty Pulling trailer uphill reved up shifting down, bogged out no throttle response wrench light on. Top of hill pull over restart wrench light out Problem repeats at next hill. ford...
It does have a towing package right? A button on the end of the gearshift that you push in when towing? It sounds like it is in too high of gear. Maybe trans fluid gets hot and turns on the light? If it dont have the towing package? Are you keeping it in overdrive? Shift it down manually and keep it in 3rd when hauling any kind of weight.
Not sure if this helps but I know peopl that have burnt their transmission out pulling trailers in O/D
Oct 15, 2011 | 2005 Ford F 350 Super Duty
2001 hd 8.1 with allison. Pulled my boat up a big hill, then the tranny warmed up just below the red line, pulled over and looked under, and it was leaking. Just dripping. Put a quart of fluid in it and...
There is no overflow on the Allison Trans, something happened when the trans got over heated, it is a good idea now to also get a trans flush as once you heat it up that bad it starts to break down the fluid.
May 28, 2011 | 2001 Chevrolet Silverado 2500HD
I was driver my 1992 chevy 4 wheel blazer up a hill and all of a
You'll have to have it removed and stripped down , to figure that problem out/
May 26, 2010 | 1992 Chevrolet S-10 Blazer
SLUGGISH TRANSMISSION
Discribe sluggish. Changing the fluid has nothing to do with shift stratagy or correct trans operation. Change the filter every time you do the fluid,unless your just pulling the plug every year or so,to change some fluid.
These vehicles have a tendency to have a bad Trans Solenoid Pack. If it bangs into reverse or shifts funny around 35 to 40 on a slight hill,that part may be going bad.
You need a proper working EGR Valve and TPS (Throttle Position Sensor) also.
Don't forget to flush the Power Steering Fluid--although unrelated to the trans.
Trans--Mercon V Fluid
Steering--Mercon (Not V)
Apr 23, 2010 | 2002 Lincoln LS
Honda passport trans light flashing
Most likely you have a bad transmission pressure solenoid. You weren't too specific so here's what to look for: The engine light, the trans light and the shifiting, if when you drive on a level surface the suv seems to shift late and very rough...that is probably what it is. It's a few hundred to have fixed because they have to pull the casing off the trans and they'll want to replace the fluid and filter too. good luck.
Nov 29, 2008 | 1996 Honda Passport
Transmission Issue
Is the fluid level ok, was the governer still in place when the gov cap popped off, have you dropped the trans pan to see if the filter popped out and is it possible that you only get enough fluid to the pump pickup when on a hill?? just a few ideas
Aug 05, 2008 | 1992 GMC Sierra
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
137 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
