Question about Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark X4200 all-in one with an error designation of error 1200 What do I do to get rid of this error
  • Lexmark Master
  • 5,263 Answers
The error means that the cartridge carrier can not move freely. This can happen if the cartridges are not correctly seated, the encoder strip is out of place or there is a foreign object blocking the path.
First check that the cartridges are properly seated and locked into place. If that doesn't help, then remove the cartridges. Move the cartridge carrier belt (black) to the left. Push the encoder strip down and then up to get it into the slot on the back of the carrier. If needed move it forward and then back to slide into place. Reinsert the cartridges and move the carrier back to the right.
Next gently move the cartridge carrier belt left and right listening for any rattling or other sounds of a foreign object. Remove anything that doesn't belong in the unit.
If none of the steps help, contact Lexmark.
http://support.lexmark.com/index?page=content&id=SO3439&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_F4270&searchid=1272215370057 has pictures.
I hope this helps.
Posted on Apr 25, 2010
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
I'm using a Lexmark X4270 And I apparently downloaded a driver for a Lexmark X4200. As of now I can't print anything. Do I need to download a driver for the Lexmark X4270 for my printer to work?
Hi!
If you downloaded the driver for the x4200 series then that is alright. But to make sure redownload the driver and reinstall it. After that unplug the USB connector to your computer and then restart the computer. Wait until you have gone into windows and logged in before plugging back the usb connector. Wait for windows to acknowledge the connection by showing an installing device message or by a series of tones. Check on your printer devices if your printer is online. Try printing a test page. If you are still getting a problem make sure to jot down the error message you are getting and get back to us here at fixya.
Feb 10, 2011 | Lexmark X4270 All-In-One InkJet Printer
Printer keeps popping up Error 1200 on The lexmark x4270
The 1200 error code indicates that the cartridge carrier has stalled. Refer to this article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One on how to troubleshoot this problem. If error continues after going through the steps, I would suggest you contact Lexmark technical support so they can further look into this issue. Thanks.
Nov 09, 2010 | Lexmark X4270 All-In-One InkJet Printer
Where can I get a user manual
You can download the Lexmark X4200 Series User's Guide from the Lexmark website at http://bit.ly/cNbUKo. Hope this helps. Thanks.
Sep 30, 2010 | Lexmark X4270 All-In-One InkJet Printer
Displaying "Error 1200" on my lexmark x4270. How do I fix it?
This error is too complicated to explain using text, so will refer you to a Lexmark support document for your error and model:
Lexmark X4270 Error 1200
Jan 14, 2010 | Lexmark X4270 All-in-One Multifunction...
Alligment
First of all u should make sure that ur able to print normal documents other than the email..... If ur able to: Go to all Programmes Lexmark X4200 series open the Lexmark Solution Center..... Go to Maintenence and click on Alighn Cartridges.......... That Should Fix the Problem if that doesnt fix it........ Go to Printers Folder on the Control Panel right click on the Lexmark X4200 Series which has a check mark on it and click on Properties then click on Advanced click on Properties the Lexmark X4200 Series and LEMF will be selected by default...... Change the LEMF to NTEMF 1.0008........ Restart ur Computer it will work.........
If ur Unable to: Uninstall the whole software......... Download the Drivers for the Printer from: Lexmark.com Download the Drivers and tried to Install the Download drivers......... That should work............ Thanku
Jan 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark all in one printer don't install on vista. is there a patch
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
exmark
  • Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
  • Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
  • Lexmark X5400, X4200, X1200, Z645, Z840, Z730, X2400, X3400, P350, X7300, X8300, X9300
  • Lexmark X1100, Z500 & Z600 (combined), P4300, X3300, X2300, X7100, Z810, Z700, X5200, P6300, P910, P6200, X6100, X5100, X2200
  • Lexmark 1100, 1200, 2400, 3400, 4200, 5400 Series, Lexmark X7350, X8350, X9350, P350, Lexmark 640 Series, Lexmark 730 Series, Lexmark Z845[4]
Dec 04, 2008 | Laplink Software PCmover for PC
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
