Have diskgo edge model hd-d1-u2 computer doesnt recognize it
Have diskgo edge model hd-d1-u2 plug it in the usb and nothing comes up. can not see any of my files. I see it has a power supply and i have never used that before....help all my pics are on here
4 Suggested Answers
  • 1768 Answers
SOURCE: I have a DiskGo! edge
1. Check for possible damaged USB cable.
2. defective USB electronics
3. new USB case needed
4. can be purchased online
5.Check for Possible damage USB PORT. Try another port.
Posted on Jul 11, 2011
SOURCE: Edge DiskGo HD-D2-U2 External Hardrive not recognized by Vista
Hi
I having samsung E-250. I want to load dictionary in my mobile .How can I do that
Posted on Apr 08, 2009
bob_computer
  • 3153 Answers
SOURCE: I need a power supply for an Edge DiskGo! USB
Also ensure the current rating is the same or slightly higher
Eg 500 mA
Do not use one with a lower current rating as this can cause problems.
Posted on Sep 18, 2009
It said if you plug in your drive and don't see drive letter should come here
It said you should go some place, but it did not say to come here.
Chech with the manufacturer.
Jan 12, 2015 | Speed Edge DiskGO 3.5" 300 GB Hi USB...
When I plug my HD in, the blue light comes on, but the motor isnt running.
Have you plugged in the AC power adapter? The blue light means it is connected to the computer but USB power is not enough to operate this drive.
Mar 25, 2014 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
Edge diskgo
Perhaps if the HDD has not been damaged. HDD's can be very delicate , external HDD's can get bumped about at times, rendering them useless. Remove the HDD from the case, using a USB to IDE/SATA Adapter ,or, a computer shop, try to test/read the disk. It can be read, but I'm not sure you want to pay the price it may cost. It can be quite expensive, and requires specialized equipment.
May 10, 2013 | Computers & Internet
I have a DiskGo! edge external model number HD-D2-U2 and i can't get my windows seven pc to see it. i am also unable to get it to format it so i can see it any ideas?
Jul 11, 2011 | Peripheral Enhancements DiskGO! Hard Drive
I plugged in the power supply, and the light comes on. However, when I plug in the USB, the drive does not show up anywhere on my computer. I am using the 500gb USB 2.0 drive, and I was wondering if I can...
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 26, 2011 | EDGE Tech Corp EDGE Tech DiskGO 500 GB...
Pc cant see my disk go edge 80gb
Hi and welcome to Fixyah,
The problem that you having was the enclosure of your Hardisk and the need to exchange it. I suggest to you if ever that is under warranty sentit back to your reseller or take the disc out and buy another enclosure for you to be able to get all your files.
Aug 11, 2010 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
I think my HP Pav powersupply is dead. When I plug it in and try to turn it on, nothing happens to the HD and computer except a green light flashes on the back of the power supply. It is a Bestec...
all atx powersupplies are generic-it dous not really matter what computer it comes from unless its a high end pc requiring loads of power-if your machine is intel you may need a supply with an extra twelve volt lead(two yellow and two black leads in a little block)-but for that pc i would just harvest a powerpack out of a dead machine
Feb 25, 2010 | Compaq Computers & Internet
Hi
Apr 08, 2009 | Peripheral Enhancements DiskGO! Hard Drive
I have a rock mobile 3.5" mobile drive model #hd2-u2
I beleive you may have damaged the HD itself. The case only contains the lights, and the power supply.
The only other way to test it would be to take it out and install it on your desktop as a slave to see if it comes up.
i feel fro you I also had an Ultra external HD 60G and burnt it by using the wrong ac adapter.
Sep 23, 2008 | Ultra 1 Bay USB 2.0 External Drive Case
Computers & Internet Logo
590 people viewed this question
David Payne
David Payne
