Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
How do i reset my ice maker on a sub zero 611?
Turn the power of the refrigerator off then back on. Simple as that.
Posted on Aug 05, 2012
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
  • 7 Answers
SOURCE: Sub zero 690 ice maker
also discovered if ice box auger not engaged exactly right with auger drive motor, then ice box won't be able to be pushed back the last half inch to engage the secret "turn on the ice maker" switches. Juice storage brackets also won't engage since ice bucket not flush with front of cover.
Posted on Aug 17, 2008
  • 56 Answers
SOURCE: Ice maker in Sub Zero 642
Call the factory at 800-222-7820 for the manual. It souns like you are missing one or two screws. Pull the ice tray out and lift it up about an inch and it should release. Take a look at the ice maker and there are two supports that both need to have screws on them. There is also a third underneath on some models. Insert the screws and you should be fine.
Posted on Dec 02, 2008
The ice-cube maker on our Sub-Zero 611 has stopped...
i have a ice cube Machine (40 Cube) But he not working Properly
I dont know the Warring Daigrams in this Machine Athore Parts is Very well Conditions plz Solution My Probalms
i Need the Simple Wiring Digrams
Thanks & Regards
9816319449
Aug 05, 2012 | Sub-Zero Refrigerators
I have sub-zero model 3211 red. My ice maker stop making ice. what to i do?
Here is a link to a Sub Zero Repair Video
http://www.appliancerepairlesson.com/shop/refrigerator/sub-zero-diy-repair-video-for-replacing-ice-maker/
Feb 20, 2011 | Sub-Zero Refrigerators
My sub-zero 680 fill arm on the ice maker will not lower. As a result the ice maker will not come on because the arm remains in the raised position. How can I get it to lower? I've tried turning off the...
Get a new ice maker. Nothing in the ice box controls the whims of that ice maker. Only it can dictate whether or not it wants to work correct.
Jan 18, 2011 | Sub-Zero 680 / S
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
Ice maker not working
You will have to pull the ice maker out, defrost fridge or use a hair drier to defrost all parts in the freezer. then replace ice maker
Jan 21, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub-Zero 611/O not cooling
sorry but i do not have experience with hte sub-zero product line, I can reccomend to you thought that it is a very expensive piecce, and replacing it ( with another sub-zero) may prove to be a more costly option then the repair, Generally a Qualified subzeroe technician, (at least inmy area) is strictly a SubZero, specialist, so although you may pay a premium for the service it will be backed by the manufacture, and only 6-7 years old i cant imagine a problem that would justify replacing the unit.Althougth Im a Do-it-your self advocate, there are somethings that are generally best to leave to a professional opinion. This would be my reccomendation
Jan 17, 2009 | Sub-Zero 611 / O Bottom Freezer...
The steel lever on the ice maker was all the way up and disengaged from making ice. I fixed it myself.
Jul 01, 2008 | Sub-Zero 611 / O Bottom Freezer...
Refrigerators Logo
592 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
