Hi! I've been trying to connect a 40GB WD IDE HDD to a SATA port through an IDE to SATA converter without any success. Here are the technical elements: Computer: ACER Aspire M5620 Motherboard: ACER G33T-AM OS: Windows Vista 64bit IDE HDD [the one I want to install as a secondary drive]: WD IDE 40GB OS on this secondary drive: Windows XP Professional IDE to SATA converter: Vantec USA model CB-IS100 Vantec says tha the IDE HDD must be Master. I tried without any jumper [Master or Single], with the jumper for [Master with Slave present] and with the jumper for Slave... but all to no avail, Any help or ideas would be appreciated. Thanks! Louis Morrissette
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Was this solution helpful? Show your Appreciation by rating it:
