Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Not sure where water goes ? in bladder and with solution on back
BISSELL PROHEAT clean shot 2x no manual does water go in with cleaner on back of machine and in the bladder on lower front and dirty water then comes in above bladder to be emptied is this right
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
qwewr
Posted on Sep 30, 2010
I have a Bissell 2x preheat 9500 and the flow gauge is not turning and the formula is going into the bladder. There is no spray on the clean shot and no water coming out of machine.
If you look at the location where the tank connects to the base, there is a socket, in that socket is a one way rubber flap. That flap sticks and wont open to allow cleaner into the pump. I used a small screwdriver to press that flap out of the way
Jul 30, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
Just need instruction on how to use
fill the solution reservoir in the back and on the bottom choose your desired setting, make sure the rubber clean water bladder is full of hot water and turn on. pull trigger and slowly move forward and backwards. Happy cleaning .Steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat 2X, How do you install the Bladder into the water tank
heatman101
dgjdjg
Mar 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell ProHeat Turbo 2x Carpet cleaner.
heatman101
tiutiu
Jan 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Want to Buy a Repair Manual for Bissell Proheat 9500 Clean Shot
I have the manual and would be more than willing to share...contact me at brewcrew2u@aol.com
Aug 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
102 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
