How do I replace fuel line on a husqvarna 142 chainsaw
This is not as easy as it sounds, this machine uses a micro bore hose which is an interference fit in the tank, to replace it you will need to remove the fuel tank from the saw, to do this start by removing the guide bar and chain, remove the three screws securing the top cover and remove, remove the two screws holding the air filer and remove, remove the two 10mm nuts hloding the filer back plate and remove, remove the two 7mm head boltssecuring the carb, remove the two cross head screws securing the metal bracket against the carb, lift the carb away with the throttle wire and choke pull attached, diss conect the fuel hose, now remove the four screws holding the starter cover on, two screws are self tapping and go into the plastic cranlcase the other two are machine screws and go into the anti vib mounts, when replacing make sure they go back in the same holes in the starter cover, on the other side of the saw remove the 4mm allen screw securing the chain catcher in the bottom r/h side of the saw, this also screws into an anti vibe mount, remove the cross head screw at the top l/h side of the saw and remove the orange plastic square cover, the fuel tank will now drop out of the bottom of the saw with the top handle still connected,pull the old fuel hose out through the the fuel filler hole with the filter still connected, ncut a point on one end of the new fuel hose and push down through the top of the tank, grab with a pair of long nose pliers through the filler hole and pull the hose in, trim the end and re fit the filter, allow enough hose to allow the filter to move around in the tank, re fit the tank and securing screws, re build in reverse of diss assembly.
Thank You, this is exactly the problem, (plastic undersized substitute fuel line)
Did you replace the fuel lines? Reply below please.
