Question about Microwave Ovens
We have the blancomaster gourmet kitchen faucet and the spray part won't function. my husband has taken it apart and can't find why the water pressure isn't going to that part of the fixture.
  • 17,970 Answers
If dont remember bad, that faucet has been discontinued; to repair is very easy, pull off center cap, remove screw, handle comes off, remove center cap nut, remove clip, pull cartridge using moen tool (home depot should loan one with a deposit) install new cartridge with the hole in the brass part of the stem to the back of the sink, now while you are in there you might as well pull spout and change o-rings apply a little grease and put it back together.
Hope this helps.
Posted on Apr 25, 2010
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
Oct 21, 2012 | Microwave Ovens
I'm trying to change the kitchen faucet and the shut off valves under the sink will not turn, I've tried to spray them with WD40 but they still won't turn. I live in a Condo so I cannot shut...
If you can't work the shutoffs on the water lines under the sink, your only choice is to contact your condo maintenance people. They need to have some way to shut the water off to your unit when they make repairs. They can tell you if there are some more valves in another area that you can access, or they may have a maintenance closet somewhere and can turn the water off for you so you can make the repair.
Sometimes you can turn a sticky valve by using a large set of channel-lock pliers or similar type on the knob so you can get leverage. They look like this if you're not familiar with the type:
If it's been a while since the valves have been used, they often don't want to move without help. Once free, they may work fine, but sometimes it's a good idea to replace the shutoff valves as part of the new faucet installation. They're not expensive and you'll know they will work if you need to shut them off in the future. Get "ball-valve stops" which make a positive shutoff. Stops that use a rubber washer can sometimes let water trickle through (or more than trickle!) when shut off. Depending on the kind of valves currently installed and the type of pipes supplying your water, you might want the condo maintenance people to do the replacement. But if 1/2-inch copper pipe is what you have and there's a couple of inches between where the pipe comes through the cabinet back or bottom and the current valves, you can just cut them off with a tubing cutter. Then you can replace them with valves that just slide over the pipe and are fastened by tightening down a compression fitting (tightening a nut, in other words).
You should also plan to use new supply lines from the shutoffs to the faucet. Again, they're cheap and the old ones can sometimes leak when you try reconnecting them. Corrosion and mineral build-up from hard water can lead to poor sealing. The current ones may also be clogged with minerals, and new ones will give your new faucet full flow.
Once you've got that problem of turning off the water supply solved, it's usually not too difficult to change the faucet. Make sure you have a basin wrench on hand; on many faucets it's impossible to reach the supply connections with any other kind. The box from the new faucet may tell you if can get away without one.
Good luck with the project, and thanks for using Fixya!
May 28, 2011 | Microwave Ovens
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
Our kitchen faucet has continued to lose water pressure over the past two weeks to the point that it's down to a trickle. We have removed the faucet to look for any clogging and there is none. what could...
You took off the faucet, but did you take the aerator off the spout? That's a very common trouble, especially if you have hard water with lots of minerals. The aerator screen gets clogged and your water slows to a trickle or is stopped entirely.
The aerator just screws onto or into the faucet, but you might need a wrench to remove it if it hasn't been off in a while. Tape the jaws of the wrench to keep from damaging the chrome unless you plan to replace the aerator. Once it's off the faucet you can take the aerator apart, noting the order of the pieces, and clean off the screen. Reassemble it and put the aerator back on and you should have your water back.
You might also just want to replace the thing; you can find replacements at hardware stores and home improvement places. Just take the old one along to make sure you're getting the right replacement.
Mar 12, 2011 | Microwave Ovens
How do I get to the cartridge to see if it is blocked in some way. I have reduced flow. This is on my kitchen faucet. American Standard Jasmine Kitchen faucet
You have to turn off the water and disassemble the valve from the top side. Check your screens at the discharge point, particles block there, also.
Mar 05, 2011 | Microwave Ovens
My husband installed a new KWC Domo faucet in our kitchen yesterday. When he was finished, he turned the faucet on and got a trickle of water. We are stumped and the instructions are no help.
Take off the aerator from the spout (it just screws on, and should not be so tight you need a wrench) and then run the water. You'll probably find the aerator screen is clogged with debris and you can wash it off. This often happens when you turn the water supply off to connect the new faucet. After you clean off the aerator and screw it back into place your new faucet should work fine.
Feb 27, 2011 | Microwave Ovens
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
