Question about Dishwashers
Indesit IDF 125 the pause light and the drying light after a few mins of operation come on and flash and the pill in the soap dispenser is still there unused. We have cleaned the filters in the bottom of the machine and also ran a bottle of Morrisons dishwasher cleaner through it but the problem pursists. The machine is only 7 months old.
Did you find out what it was? We're having the same problem.
Posted on Dec 13, 2012
2 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: indesit idf 125 dishwasher
you don't need salt in the dish washer?
Posted on Feb 12, 2009
How do I Fix upper spray arm to Indesit IDF 125 UK
It depends a lot on what is wrong with it. You can get special glues that fuse plastic if it is broken.
If you need to replace it, appliance spare parts are available online.
If it is intact but still non-functional, try taking it apart to see if something is causing it to bind.
Past this, your complaint should direct the course of your remedial action. You did not say what was wrong initially.
Good Luck,
Pete
May 23, 2015 | Indesit Dishwashers
I have idf 125 indesit dishwasher i fitted a new water solioned but it will bring in water but pumps it back out and lights flash what is the problem
These machines use the wash motor to measure the water level.they measure the load on the motor which tells it when the water has reached the correct level.
Your dishwasher is sensing that there is too much water, they are a semi timed fill. try turning the inlet tap down a little and see if that helps.
If not the issue is either in your electronics or in the motor, The electronics sometimes get dry joints and if you have a soldering iron they are an easy fix.
Mar 06, 2012 | Indesit DF125 24 in. Built-in Dishwasher
Hello What does the error code A13 represent. The soap dispenser seems Ok. Could it be related to something else. The machine starts up Ok, but about 6 seconds into a cycle A13 flashes up and the...
As you correctly pointed out A13 error is linked to the failure of the detergent dispenser lid operation.
If the lid is not opening at the correct time in the wash cycle, then the detergent will not be getting dispensed.
Either the controller circuit that operates the lid is faulty or the lid solenoid is faulty.
You can check the parts at this site.
Mar 20, 2011 | Indesit 24 in. DE73 Evolution...
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
It doesn't start and clean light flashes Kenmore Elite dishwasher water supply is turned on overfill protection float is able to move up and down freely there are no sudes in dishwasher soap dispenser...
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Dishwashers
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Indesit idf 125 dishwasher
Feb 11, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Indesit evolution DE73 frozen program
I have the same problem. You need to switch it off at the mains for at least 20 mins.
Aug 14, 2007 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
200 people viewed this question
Top Dishwashers Experts
Owen Barnes
