Question about Kenmore HE2 Plus Front Load Washer
Give me the F 21 error. One thecknician told me that the Pomp is broken and is asking for a $400 reparation cost? This machine is only 14 month old... Thanks for your help.
  • 15,935 Answers
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
(Tip courtesy JSRock)
Thanks for using FixYa - a 4THUMBS rating is appreciated for answering your FREE question.
Posted on Apr 25, 2010
E21 error code on Bosch washing machine
check with http://erepairparts.com/ we have no idea what prices are where you live .
May 27, 2015 | Bosch Washing Machines
I have a Maytag MAH-24 Washing Machine showing a 5E error code
You will have to contact Maytag and speak to their service dept and give them your model number. Ask them what a 5E eror is and when you call for service, tell the repair facility what Maytag told you. That will next to eliminate labor cost for Diagnostic.
Apr 17, 2012 | Maytag Washing Machines
I dropped my razor phone in lemonade a couple months ago. I was wondering how much it would cost to get it fixed or if it can even be fixed.
I can't give you an exact number of how much it will cost, but from my own experience if you drop it in to the ocean (water) it will cost you about 100$ which is not cheap. And as you dropped it into lemonade I am sure it will be even more expensive. This is what I think you can expect, but before you buy a new phone you can always ask a local reparation service company for exact numbers. But I think a new phone is the way to go, unfortunately.
If you find this comment useful, please give it thumbs up and good luck! :)
Jun 08, 2011 | Motorola Mobility RAZR V3
I lost the Buttonhole fine-adjustment screw for brother ls2125
I just wanted to share my situation with you. I had the same problem. When I tried to use my Buttonhole fine-adjustment screw, it broke up and fell inside the machine. My husband opened the machine to get the broken parts out (two of them: first one - white-colored plastic broken part of the adjustment screw and a metal, half-moon shaped washer).
I called 1-877-276-8437 (BROTHER), and the person who checked the list of replacement parts said to me that this particular screw was not in the list. So that person gave me the number of the closest service center where I called.
The service person told me that it was no cost to see what was the problem, but to determine how much the solution would cost he needed to see the machine. I asked about the minimal cost of a service; it was $89+ the cost of the parts. It means the minimal cost of the repair (without the price of the replacement part) goes 14 dollars beyond the price of a new machine, which in Amazon.com today 10/2011 is $75 for the same model LS-2125(i).
My solution was to get out the broken part for which my husband unscrewed for me the front plastic shell and took out the two little broken parts. During this procedure, he realized I could use a narrow scissors to make the remaining part of the Buttonhole fine-adjustment screw turn around. This way I can still use my machine with no need of buying a new one.
Sep 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
Similar issue
dear friend-the warrenty on a clutch is only 20 000 km,therefore you have to pay for the replacement,but 2500 dollars is a bit steep i suggest you get more quotes befor reparing.
Jun 30, 2009 | 2006 Hyundai Tiburon
Touch screen not functioning after falling down
the touch panel costs 1500 bucks if u give it in redington, chennai.
phone lock cost depends upon availability and the goodness of the service people. I got it changed for 115 rs. Board and socket connection, am not sure. But if u ask me, better buy a new one than spend this much amount.
Mar 31, 2009 | Motorola Mobility ROKR E6 Smartphone
Parts for a brother MFC-7420
you better double check that model number. i'm thinking you mean the mfc 9420.
razors
Feb 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
My Tricity Bending Washer/Dryer
yes they are it costs about £120 this is a major repar
Feb 07, 2008 | Tricity Bendix AW1000W Front Load Washer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
No picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I have a Sony KDL40S2000 and three months out of manufacturer warranty my TV made a clicking noise similar to feedback in a bad sound system and went to black screen. The error was not recoverable and four blinking lights were seen by a technician. I bought the extended warranty from my store, so I was covered. After one month in the shop, the technician brought my TV back today and told me the panel was replaced which would have cost me 1000 dollars if I wasn't covered by the store warranty. I read on another site the four flashing lights can mean a bad inverter. I don't know enough about TVs to tell you if the panel and inverter are one in the same, I just know you need to get it repared if you get four blinking lights at a huge cost!
Dec 18, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Kenmore HE2 Plus Front Load Washer Logo
55 people viewed this question
fordexpert
Mike Squire
Robert Rankin
