Question about Canon PowerShot S2 IS Digital Camera
When switched on there is no image in the view finder or on the display
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Apr 25, 2010
I cant see through the Viewfinder its just all black but i can see on the led screen and i can switch the display to he view finder and see it fine , so is the viewfinder broken ?
It is not likely the view finder is broken, because it is deep inside the camera. There can be many reasons why you can't use it as it should. Did you know you can adjust the brightness of the viewfinder and the display separately? It is in the manual page 31. And if you are with the manual (still online available) have a look on page 16 too.
When the camera does not give the image to the view finder, it also could be an electronic problem, because switching in the camera goes along electronic paths.
Jan 19, 2014 | Canon PowerShot Cameras
Off lens,view finder is not workink
The view finder is the little window on the top left of the camera. If you want to use the display as a view finder, you have to press the button with the camera logo. It is called the life view mode. you use the same button to switch off the display. Be aware using the display, will drain the batteries quicker. Somewhat faster then with modern cameras.
see page 19 of the manual.
Dec 02, 2013 | HP Photosmart M307 Digital Camera
No picture on screen when switched on
You have not given enough information. Are you trying to see
recorded photos or expecting to see the image from the lens?
You normally have an option to either use the view finder OR the
LCD display. It usually defaults to the view finder and you must activate the LCD with a button.
Nov 02, 2013 | Samsung Cameras
View finder displays are upsidedown
Telescopes generally will display images upside-down, due to the way the image is magnified. On many telescopes, the eyepiece is removable, and can be exchanged with many different attachments and lenses. One of which being an image rectifier (or image flipper), which flips the image back to normal. Unfortunately these lenses can be pretty expensive, and will reduce the amount of light being passed through the telescope due to the addition of more lenses, so are only primarily used for day terrestrial viewing. Hope this helps.
Mar 24, 2011 | Edu-Science (10166) Telescope
I have a fugi fine pix, when using it in bright sun light i cant see anything
Geofchaam,
You could be experiencing one of two issues:
1) You are having a difficulty viewing the image on the back of the camera (not the view finder). This is common on cameras out in the sun, try cupping your spare hand over the screen to cast a shadow on the screen.
2) You cannot view anything in the view finder. Since the view finder has its own tiny LCD display inside of it, it is displaying what image the camera will take if you press the shutter release. I would double check to see if the camera is set correctly for shooting in bright sunlight (check your owners manual, or set the camera to Automatic), and if there is a difference between what you're seeing in the viewfinder, and what images the camera is taking, consider calling Fuji, as it sounds like a hardware issue.
Mar 01, 2011 | Fuji FinePix S5000 Digital Camera
My Canon G9 display screen has stopped working. It can view an image but does not work as a view finder!
Press the "DISPLAY" button until you get the display you wish. You can choose the information you want overlayed on the image in the custom display settings, see pages 55 onwards in your user manual.
Feb 01, 2011 | Canon PowerShot G9 Digital Camera
D80 Monitor does not function as view finder.
To be able to do what you want, your camera would have to have a feature called "live view"....yours does not.
Jul 21, 2010 | Nikon D80 Digital Camera with 18-135mm...
Finder focus problem
is there a little slider type bar/switch/button on the finder, most cameras have them to compensate for different peoples eyesight. if there is, look through it, put camera in auto focus and when its focused, look through finder and move bar/switch... til pic is clear
Sep 21, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Canon PowerShot S2 IS Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
