Question about Garden
My 14SB John Deere mower will start but then quits before moving the throttle, changed oil, oil filter, spark plug, new oil, added fuel stabalizer to gax tank. Any ideas???
  • unlevel Apr 26, 2010
    Thx, I pleased to say that after replacing air/oil filter, spark plug, new oil, gas stabalizer/conditioner AND tightening the carburator bowl nut . . .I'm back in the lawn mowing business.
    Little Woman
  • Anonymous Mar 23, 2014
    Transmission oil change
  • 10,865 Answers
Hello. You have some winter buildup in your engine. Get a can of starter fluid and a helper. have the helper shoot small squirts of starter fluid into the air filter while you run the mower. In just a couple of minutes the starter fluid will clear your problem. Joe
Posted on Apr 25, 2010
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere LA105 lost power
Hi Hank:
Did you hit something with the mower, or did it happen gradually?
Probabaly a good idea to start with a basic service:
- Clean air filter
- Clean fuel filter
- Flush carbuerettor
- Fresh gas?
- Change spark plugs
- Change oil and filter
- Underside of mower deck clean and free of all built up grass?
Hope this helps.
May 09, 2015 | John Deere Garden
John Deere will not start. fuel filter dry
some models have a fuel pump some are grivitey
May 03, 2012 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
We have a John Deere lawn mower model JS45. Just
this problem is related to the auto-snesing carburator. If you wrap the throttle cable, that runs down the left side of the mower, around the handle several times and tie wrap in place the mower will run. I had the same issue with mine. the manual is vague at best when it describes how to fix. After you wrap the cable around the handle, it will tighten the cable and the mower will run.
JV
Feb 28, 2010 | Garden
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Garden
Garden Logo
521 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
