Question about Campbell Hausfeld 26 Gallon Low Rider Compressor WL8027
Compressor shuts off at 60 psi will not come back on until opsi
I have 26 gal. Husky. It has just been rebuilt with a new motor and compressor. Now it kicks off at 60 psi supposed to shut off at 120, and it will not kick back on until 0 psi. Thanks for your help
    Problem Solver:
  • 12 Answers
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Posted on Apr 29, 2010
My husky 26 gal air compressor will not stop running
Sounds like you have a faulty shut-off switch...
Replace the shut-off switch with a new one...make sure it is of the same shut-off and turn on values
Mar 30, 2013 | Air Tools & Compressors
Motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Aug 31, 2012 | Husky Air Tools & Compressors
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Brand new Husky 60 gal 3.2 hp runs to 30 psi and then starts bogging down and running and bogging down ect. No more pressure over 30psi and i can hear on and off clicking of the motor. Did I wire it wrong...
SOUNDS LIKE IT WIRED FOR 220VOLTS AND YOU HAVE IT PLUGGED INTO 110VOLTS. IF THE MOTOR SAYS 110/220 THEN FOLLOW THE DIAGRAM FOR LOW OR HIGH VOLTAGE. MAKE SURE CORD IS ADEQUATE SIZE. HOPE THIS HELPS.
Apr 25, 2009 | Campbell Hausfeld Air Tools & Compressors
My Sears 1 HP compressor motor starts to slow down to almost zero RPM as pressure approaches 60 psi. Up until recently it produced 100 psi. Compressor rotates freely at shut down (no binding, etc). Is this...
IF IT HAS BELTS THE BELTS COULD HAVE BEEN LOOSE AND SLIPPING.. MOTOR COULD BE GETTING HOT DUE TO TOO SMALL OF CORD OR SMALL GAUGE DROPCORD. INTANK CHECK VALVE COULD BE GETTING CLOGGED NOT ALLOWING AIR TO PASS THRU IT. UNHOOK DISCHARGE LINE FROM HEAD TO THE TANK, THIS WILL ALLOW PUMP TO RUN UNDER NO STRESS AND SEE WHAT HAPPENS.
Apr 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Campbell Hausfeld 26 Gallon Low Rider Compressor WL8027 Logo
598 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
