Question about Jenn-Air JCD2389G Side by Side Refrigerator
I have a Jenn-Air JCD2389G Side by Side Refrigerator. The bottom of the freezer keeps things frozen, though the top of freezer & refrigerator remain mild to warm. There is not an excessive amount of goods at the bottom of the freezer. How do I increase the chill?
    Problem Solver:
  • 13 Answers
It sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Posted on Jun 03, 2010
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and...
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
I have a Jenn air side by side refrig/freezer
Hi rdiorio.
you could have one of many faults, either thermostat, compressor or if electronic maybe that have failed. If the Thermostat starts to fail it can produce eratic readings which freezer the chiller part of cabinet, then it can fail completly. What ever you do remember 240 Volts kills. Use a qualified person when dealing with electrics... Cheers
Mar 29, 2010 | Jenn-Air JCD2389G Side by Side...
Our refrig is not cooling and now the freezer
It could be two things. it is either the defrost heater or the time. (some models have adaptive timer. but before you guess here is how to check (be very careful) you need to get to the defrost heater and apply 120v directly to the heater. if the heater go on then the timer is bad. if the heater dont work then it is the heaters. in either case you must change the bi-metal t'stat along with the timer or the defrost heater.
Mar 22, 2010 | Jenn-Air JCD2389G Side by Side...
My Jenn Air refrig model # JCD2389GES is not cooling on the refrigerator side but is fine on the freezer side.I changed the thermostat and was good for 40 days,then the nightmare started again.
the problem is in your freezer
you need to opaen the wall inside the freezer and see if there is ice build up on the coil.
if it is frozen heard you need new thermostat or heating element. check it first and let me know what you see.
open the back wall (the bottom one)
Feb 07, 2010 | Jenn-Air JCD2389G Side by Side...
My refrigerator is't cooling & my freezer is
Pull down plastic panel inside which covers the temp adjustment. In center there is small panel and under neath is computer chip board R&R board. This should fix your problem but be sure to turn ref off and defrost the chiller tubed on freezer side before starting back up
Denny
Jun 24, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389GTW Refrigerator problem
Check the back wall of the freezer section for frost. If it is frosted you do have a defrost problem. Timer or heater related. More economical to repair than to buy a new system.
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air refrigerator problem
Couple things to check first is that your evaporator fan motor is running, located in the back of your freezer. open the door and listen for the fan some work on the door switch make sure you depress the switch to check it. If the fan is not running more than likely you need a new fan. The second thing is just look at the back of the freezer compartment and look for a layer of heavey frost if there is heavey frost then your defrost is not working, will need to manually defrost and probably replace the defrost terminator part of the heater assymbly
Feb 10, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
188 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
