Laptop Acer does not see AC power
my laptop Acer (TravelMate 4152LMi) does not see that it is connected to the AC power and it run the battery until it is exhausted and now I cannot use it at all.
When it still had the battery, the AC power indicator would disappear for no reason and appear only after the restart.
Now, when I plug it into AC power, the green light of the charger is lit on, the power light of the laptop is lit for some seconds, then it blinks at regular intervals (half a second after some noise, probably, of the hard disk but I am not sure) and it does not charge.
  • 3 more comments
  • gskcbr Mar 24, 2008
    Dear Wiz,
    Without the battery it works fine.
    Does it mean that the battery is faulty and I have to change it?
    Thank you!
  • gskcbr Mar 30, 2008
    Actually, when it works on AC power, it is all fine until a sudden moment when it stops as if the electricity were cut.
    So, I suppose the problem is not the battery (or not only).
    It really stops working abruptly and next time I switch it on, I have "to check the disk for incosistencies because the computer was not shut down properly" (on a blue screen before I can log on into Windows)
    The last time I switched it on (to try settings of hibernate) it turned off while checking the disk for incosistencies.
  • gskcbr Mar 31, 2008
    Hibernate was at 6 hours, I put at "never", and several seconds after that it switched off completely.
    (I couldn´t/ did not have time to enter into safe mode)
    And when it switches off, it is not like hibernation, it does a fraction of a second, without any preparation, as if unplugged.
  • moonfyre13 Nov 17, 2008
    mine is doing the excat sam thing. I got it secondhand and was fine for a few weeks now it is doing this? also runs only for a minute or 2 on ac only beforing just turning of with going on standby or anything. What can I do?
    Genius:
  • 3,587 Answers
Ok..try it without the battery installed at all, and let us know how that works..AC power only..
Posted on Mar 23, 2008
  • Patrick Michaels
    Patrick Michaels Mar 30, 2008
    ok..so it works for a short time on ac...turn it back on, and go to your display settings, and see if the hibernate is set(behind advanced in display settings) turn that off, and see how it comes through..
  • Patrick Michaels
    ok..use F2 to get to the Safe mode, and try it from there.
SOURCE:
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
How do i turn on wireless on my acer travelmate 612 TXi
You should have a little thing switch on the front or side of your laptop you can flip on. if you dont have a switch then go to start>connect to> show all connections. after that you will see wireless network connection, right click on it and enable it.
Feb 26, 2011 | Lifetime Acer TravelMate 612TXi...
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
I cant remember the start up password for my old acer 520 travelmate how do i boot my laptop please
The older Acer computers stored their passwords in the CMOS, so all you have to do is remove the CMOS battery for 30 minutes. Here is the proper procedure to do it correctly.
Disconnect the ac power adapter and remove the laptop battery. Push the power button for 10 secinds to drain any residual power. Remove the CMOS (RTC) battery for approx. 30 minutes. Replace the CMOS battery and attach the AC power adapter only, leave the main laptop battery out for right now. Power the laptop up and let it post. If it still asks for a password, leave it blank and try hitting enter. If it accepts the blank entry and posts, then you can enter the BIOS and change your settings.
Below is the link for your service manual to assist you in the removal and tear down of components for your system.
http://tim.id.au/laptops/acer/travelmate%20520.pdf
Nov 26, 2009 | Office Equipment & Supplies
Power up issue
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 20, 2009 | Acer Computers & Internet
Acer travelmate does not battery charge but pwr jack, battery ok
First power drain your system take the battery out unplug the acadapter and then push the power button on the laptop and keep it pressed for 2 mins without connecting any power souce this will drain the static power from the syteme after few mins connect the battery first and then connect the ac adapter that should take care of the issue.
May 05, 2009 | Acer TravelMate 2300 Notebook
Wireless only available when powered by intergral battery
Did you double post this question? I think you might have a hardware profile set up not to turn off wireless when in plug mode. If that isn't the case look in the BIOS and see if there is a setting in there. You could also check the power settings on your laptop.
Good luck,
Armymason
Feb 26, 2009 | Acer TravelMate 4200 Notebook
Battery status LED blinkings amber
Try removing the power cable and battery, while these are removed press and hold the power button on the laptop for 30 seconds. this is called a hard reset, what it does is drains any residual power in the laptop. if this does not work, that means there is an issue with the motherboard. to have it sent in would cost about $398, give or take.
Jan 25, 2009 | Acer TravelMate 3260-4874 Notebook
When on AC will not charge or operate as AC powered.
You Need To Replace The DC Jack..< the port where your AC Adapter plugs into the laptop>
Nov 19, 2008 | Acer TravelMate 2201LCi Notebook
Acer laptop problem
Is the charging light on when connected to ac, is the battery old or new? The power supply connector might be faulty either at the cable side or inside the laptop.
Jan 12, 2008 | Computers & Internet
Open Questions:
Malwarebytes Antivirus CUsToMeR SUpPoRt I{;855;536;5666} nUMBer O%+& Malwarebytes Antivirus CuSTomEr Support Number @+1855 536 5666 tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 17, 2019 | Carrier Computers & Internet
Computers & Internet Logo
163 people viewed this question
Ekse
Alun Cox
