Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman furnace manual model # 7956A876 This furnace is about 15 year old and has never been used. It was removed fron a mobile home trailer. Since it was to be used in a seasonal mobile trailer is was never connected, The enclosed instructions and manuals were lost over the years. Could you tell me where I could obtain the necessary information for the installation.
    Guru:
  • 1,524 Answers
Wires to big to fit in new coleman furnace breaker
Go to Home Depot, get a wire splitter for each wire coming in (probably 2). Then run #10 to the 30 amp breakers or #4 wire to the 60 amp breakers. Harder to explain than to do. Basically, what they do is act like a "Y" branch for wires; the existing #2 wire goes under 1 screw lug, the new #10 & #4 go together under the other lug. Another solution that I do often is reuse the bus bar from the old furnace on the new furnace, properly wrapped in 10- 20 mil tape! Hope this helps! Last note: use NoLox on ALL the connections, as electric furnace lugs get hot and tend to losten over time, causing arking that destroys the lugs. Also, I'd bet your old wires are aluminum and your new wires are copper- another reeason for No-Lox!!!
Feb 22, 2013 | Coleman Mobile Modular Home Electric...
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
How old is my Coleman Evcon Furnace, Modle Number: DGAT056BDE? I can't seem to find a Manufacturing date sticker. It was claimed to only be a year old, now living here a year it would now be 2 years old. ...
The Serial Number would really help in defining how old your Coleman furnace is. The model you have is used predominantly in manufactured housing. To find the Serial Number, you will need to remove the upper shroud of the furnace. There should be a sticker or plate on the back of that shroud of just inside the housing of the furnace, that will give you the Model # & Serial #. Armed with that, you can do a little detective work, as to it's age.
Mar 03, 2011 | Coleman Heating & Cooling
Install automatic ignition system for a coleman furnace
For sure turn off the power at the breaker!! Now as far as the new board, usually the new board will be a new modified replacement, the wiring will be different from the original. It is very important to follow the installation instruction that come with the new board, if you go step by step, it will be ok. Just don't be surprised when you find that the new one is not exact. It is all in the name of improvement, follow the install manuals, step by step. As a 30 year Heating and cooling tech, it was very worrisome when they started doing this, but as long as you have a board that matches the brand and model of your furnace, it will be ok.
Good Luck,
Paul Gibson
Mar 31, 2010 | Coleman Heating & Cooling
My furnance is acting up you turn it on it clicks on then lights the flame gets big then seconds later the flames go out and the blower kicks on what could be the problem ive had several people look at it...
If the fan takes too long to come on, the high temp limit may be opening. Could be a defective limit, hard to say without more info. Another possibility is a mis-adjusted heat anticipator. A normal setting would be around .45 amp. The heat anticipator is inside the cover of the thermostat (older, analog style). Good luck.
Nov 28, 2009 | Tools & Hardware - Others
Looking to find an owner's manual for an old furnace
I remeber we took out a Coleman kero heater out of my grandmothers mobile home. Just had it repaired but she wanted a new unit. Would have to go and check to see how many BTU's it is and also to see if the book is there as well.
Jan 29, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
809 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
