Question about HP Mobile Remote Control For Pavilion Dv4/Dv5/Dv7 Series PC
Power jack for hp dv5 laptop is broken. Looking for a diagram to explain the connection to consequently rig a makeshift connection from the 12v out cable into the laptop.
  • 344 Answers
Power jack is soldered to the motherboard so it will be difficult to rig and the chance you could fry the board altogether, you can buy new jacks from ebay quite cheaply, just have to be good with the soldering iron.
http://cgi.ebay.co.uk/HP-COMPAQ-DV5-LAPTOP-DC-JACK-POWER-SOCKET_W0QQitemZ360250480816QQcmdZViewItemQQptZUK_Computing_Laptop_Accessories_LaptopCables_Connectors?hash=item53e09a18b0
Posted on Apr 25, 2010
  • badass tech Sep 18, 2010
    The hp pavilion dv4,5 and 7 power jacks are not soildered to the mother board, they sit in a metal frame and power wires go to the mother board were they plug in. Very easy fix for those who have the know how.
  • 846 Answers
. If you want to pay to have somebody do it for you there is a third party HP Repair Service. However, if you want to do it yourself, the part is available on ebay. Here's an HP Repair guide. Maybe a tech savy friend can do it for you.
Posted on Jan 21, 2011
Hp pavilion dv5-1125nr dvd player does not read cds or dvds it spins i did drop the laptop can i remove and reinstall the drive and try that? how?
Yes you should try that if you really think it is broken. Make sure you pull the DVD drive slowly and carefully. Also make sure you know how to take it out. You don't want to break it.
Sep 03, 2011 | HP Pavilion dv5-1125nr Notebook
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
I have light where power cord plugs in but nothing else. I do not have a screen or any kind of power unless i hold the on button down and the lights will flash just under the screen, but nothing else
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 08, 2010 | HP Pavilion dv5-1000us Notebook PC
Hi all please i need a hardware specialist who is conversant to the HP compaq 6735s AMD sempron 1gig ram notebook to help me on this one i made a mistake trying to use the ac adapter for another hp...
internal component failure close to adapter socket Maybe user serviceable problem with recent surface mount components not really repairable by consumer
Sep 06, 2010 | HP Compaq 6735s Notebook
How do I fix a loose power connection on a HP Pavilion dv5-1000us.
hello, you can do it but its alot of work. you need to dis amble the whole computer so you can work with the motherboard, when you have done that you need to solder the power connection. its not that hard just much work.
Oct 12, 2009 | HP Hewlett Packard Pavilion dv5-1000us...
Ineed to access the power jack? How do i get
go to hp.com you can download manuals and drivers for your specific laptop,
on a side note, It has been my experiance that the power jacks are soldered on the mainboard and then thinly coated with glue so they hold position, keep that in mind because with yours being loose the odds are that the glue around your power jack is broken, so when you pull the jack out from the plastic case be careful not to break the solder connection on the mainboard
Sep 27, 2009 | HP Compaq Presario CQ50-110US Laptop
HP pavilion dv5-1125nr notebook, dial up modem is not working
Save yourself alot of grief. Purchase a PCMIA or USB modem and your done. A very inexpensive fix. I am a certified HP Master tech and I will tell you that HP does have some consistent problems withg their modems. If you can spare a few bucks go to www.driveragent.com and try to locate an updated driver.
Jul 30, 2009 | HP Pavilion dv5-1125nr Notebook
HP Pavilion dv4000 won't turn on/freezes
1. Try logging in SAFE MODE
2. If done tell me. We'll take it further
May 23, 2009 | HP Pavilion dv4000 Notebook
HP Mobile Remote Control For Pavilion Dv4/Dv5/Dv7 Series PC  Logo
1,402 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
