Question about IBM Wheelwriter 30 Typewriter
Wheelwriter 3 printwheel
My trusty wheelwriter 3 suddenly stopped printing. the letters are not hitting the paper. i tried a new ribbon and a different printwheel.
are there any other items i can check before i need to replace the solenoid pad. i have a replacement solenoid pad, so can you guide me through the necessary steps. thanks.
  • joleneg Aug 27, 2008
    Replaced cartridge having trouble as above.
    Don't know what or where the print solenoid is.
    Thank you
    Jo
    Ibm wheelwriter 3
  • leasa08 Aug 28, 2008
    When I type I only get the top of the letter. I have changed the ribbon and tried to clean, still no luck
  • IBM Master
  • 3,594 Answers
If you know where the print solenoid is try a few drops of oil on the front and rear of the plunger. If the pad needs replaced it can be done without removing the printer from the machine but it is tough. If you know how to remove the printer take it out, remove the printwheel, there are two screws that hold the solenoid once the dolenoid is out the installation is simple.
DickyO
Posted on Mar 25, 2008
Need help with wheelwriter 3 which is not printing. Works but nothing on paper
See page 3-5 @
http://www.national-elec.com/IBM%20&%20Lexmark%20Typewriter%20operating%20instructions/Wheelwriter-3sII.pdf
Sep 06, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
I have a Lexmark 1000 Personal Wheelwriter and the daisy wheel does not easily slide into place. It then just keeps turning until the machine beeps and it stops. Will not type of course. Is there a...
No, the printwheels are the same for all Wheelwriters. Make sure the letters face the roller when you put it in (pull the print hammer assy back and check for paper clips, ribbon pieces, etc. first).
Jan 02, 2011 | Lexmark Wheelwriter 1500 Typewriter
My letters are not clear even after I've ordered a new ribbon. Could it be that I need a new printwheel? Thanks
You can try making sure all the wirng to the print wheel is secure, as a loose connection will reduce the power going to the wheel motors/solenoid (whatever actuates the wheel) and make the letters faint... Check the cables, unplug and replug all the cables and make sure they're dead straight and fully home.. if this makes no difference it could be time for a fresh wheel or maybe there is a power supply fault? Also there could be bits of paper/dust in the mechanism of the wheel stopping it hitting the paper at full strength, check around the wheel and if anything is stuck in the workings you can tease it out with a toothbrush. hope this helps.
ALSO - are you sure the ribbon is not dried out? a "new" ribbon may have been on a shelf for years and actually be totally dry...
Jan 25, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Wheelwriter 6 - Was typing and it just stopped printing. The keys repsond, the printwheel responds but doesn't move forward to make contact with the paper. The ribbons advances, the correction ribbon...
Solenoid pad is worn out. Look below left of the printwheel down inside the carriage and you should see a little white or opaque rubber pad. It needs to be replaced. You have to take it to a shop for proper repair. I have in the past, replaced it by digging the old one out with tweezers and hook. Then fish the new one in there.
Sep 07, 2009 | IBM Wheelwriter 30 Typewriter
My ibm wheelwriter 5 does not print
Is the ribbon moving? Possible ribbon feed motor bad.Can you hear the printwheel letters hitting the paper? If not, then the solenoid pad is broken. Easy repair for a tech. A 7 to 15 dollar part depending on where you buy it. You can see it down on the left side of printwheel in front. A little round white or opaque pad. I have used a pair of tweezers and small bladed screwdriver and slipped a new in. Takes practice. Otherwise, you have to remove the carriage and take the solenoid out.
Jun 10, 2009 | Lexmark Wheelwriter 3000 Typewriter
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a
Try typing on a mulipart form. If it types on the copies and not the orinonal the ribbon is the problem. If it dosen't type on the copies then the plastic cap on the print solenoid is broken.
We sell the cap with installation instructions for 20.00 includes shipping.
DickyO
216-241-0027
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
Jun 20, 2008 | IBM Wheelwriter 30 Typewriter
Light typing
What make and model typewriter do you have?
Jan 07, 2008 | Lexmark Wheelwriter 30 Series II...
IBM Wheelwriter 30 Typewriter Logo
274 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
