Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa mp3 when i plug in my mp3 the computer does not recognize it as being plugged in and there was no software with the player when i bought it
  • 1 more comment
  • Anonymous Mar 24, 2008
    won't charge
  • elizabeth880 Mar 27, 2008
    my battery went dead now everthing seems to be gone from my mp3 play .all i get it the sandisk screan pictcher . how can this be fixed.
  • Anonymous Mar 28, 2008
    No display in the screen and the computer does not recognize the player either.
  • 3 Answers
Do you have a USB cord to connect it to the computer? If not, you should get one and that should fix the problem. If you do, then you need to buy the CD that comes with the ScanDisk Sansa c250 when you buy it new and install the Sansa Media Converter and that should fix your problem.
Posted on Mar 28, 2008
When i plug in my mp3 the computer does not recognize it as being plugged in and there was no software with the player when i bought it
Posted on Mar 25, 2008
PcExpert
  • 293 Answers
SOURCE: sansa e250 won't recognize sd card.
Try charging your mpr player first. -is your SD Card brand new and with warranty? I think its deffective. Return it for replacement.
Posted on Sep 14, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa scan disk mp3 player
guest - you must have Windows Vista - it's not compatible
tooth -
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Posted on Jul 06, 2008
  • 24 Answers
SOURCE: my computer does not detect my mp3 player sansa 4.0 gb
try to reset it
Posted on Oct 17, 2008
  • 13 Answers
SOURCE: computer wont recognize sansa clip mp3 player
Reformat clip with disk utility after looking at it like an external disk. Do this by turning it off. Puting it in lock mode. Hold down middle button as you plug it in.
I am mad at my Clip as it did the same thing.
Screen shot here:
Sansa clip not recognized.
Posted on Dec 26, 2008
  • 54 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Posted on Mar 10, 2009
New computer running windows 7, doesn't recognize mp3 player sansa clip when I plug it in. downloaded latest driver but wouldn't finish download because computer isn't seeing device.
Hi there,THe reason it isnt recognizing is becuase of your OS,windows 7 has porblems
recognizing devices such as your mp3 palyer...i reccomend redownloading the software driver and if all else fails return your mp3 palyer..
please rate me full... :)
Jan 22, 2011 | SanDisk Sansa Clip MP3 Player
How to uploadmp3
plug in the mp3 player to the computer using a usb cable provided for you when you bought the mp3 player. then it will recognize that as new hardware and it will install the software for it. then you can synch it with rhapsody or windows media player 11. its simple. once you plugged it into your computer open up windows media player then click on copy to cd or a device (on the older versions) or synch (newer version) and then it will copy all of your selected songs into the player for you
Jul 10, 2009 | SanDisk Sansa m240 MP3 Player
Computer wont recognize sansa clip mp3 player
Screen shot here:
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Brand new Sansa Clip not recognized in My Computer
Hello!!
try connecting it to other USB slots!!
Nov 04, 2008 | SanDisk Sansa Clip MP3 Player
Sansa c240
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I Need a link for the installation software for sansa
http://www.sandisk.com/sansa/#/support-0/
go to Sansa e200 series for the software
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Ask about my sansa clip
does it come with anything else like a cd or usb clip with the software?
Apr 28, 2008 | SanDisk Sansa Clip MP3 Player
Unable to install software for sansa e 260 R mp3 player
Go to settings on your sansa and scroll down to USB Mode.
Change it to MSC.
Apr 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa Mp3 player help!!!
I did all of that, in fact when I tried to re-update the converter, it told me that I had the latest version but the converter still will not recognize that my player is plugged in. Windows media 10 workds great for loading cd's but I cannot load pics or vidoes, I need the converter.......anyone know what to do next?
Dec 05, 2007 | SanDisk Sansa E280 MP3 Player
Computer will not recognize player
Connect to the internet and install the sansa media converter and check to see if you have the right windows media player(11 works best but you can make do with 10)
Sep 18, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
