Fault code ( nocn ) on a ferroli boiler
I have a new ferroli optimax 38c boiler and its showing fault code ( nocn ) its not in the book does anybody have any idea.
  • 9 Answers
If nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Posted on May 04, 2010
Hit it with the palm of your fist lightly just to the left and below of the display panel, it's a loose circuit on the control board that is stopping the relay from kicking the main system into life.
Posted on Aug 01, 2015
Hello! I've got a Ferroli Optimax HE Plus 31c boiler with the F37 fault flashing.
Try bleeding the air out of the rads then represure system
Sep 17, 2016 | Heating & Cooling
Fault code f35 on ferroli optimax he plus 38 c
You simply need to get an electrician to check the power supply to your property, with a frequency meter if it tests OK then you will probably need to replace the board on the boiler, it has to be said that the incoming mains frequency is set by the supply system and generally cannot alter but some local conditions can have an undesirable effect, any good electrician will have a frequency meter on his van and will take only a few minutes to test.
Air Conditioning Coral Springs
Mar 03, 2015 | Heating & Cooling
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
Is it possible to bypass the timer clock on the ferroli optimax he 38c
I don't see why not, just keep a eye on it, and run it only when you are using it. shut it off when not in use !!! stay clear of the pop off valve when checking it !!
Feb 02, 2012 | Heating & Cooling
Ferroli optimax he 31c. brand new system will only heat 3 of 8 rads. boiler on 90c will only burn for 15sec then D2 shows and it cuts out. Why??
it is either your pump is not running or blocked [ debris from installation ect ] or your diverter valve is stuck partially open allowing a little water to pass into the heating system [ usually first rads on system ] it runs for a short while and cuts out because your overheat stat is kicking in because of poor circulation [ it is only running around the primarys in the boiler where it quickly reaches the over heat limit ] temp tends to rise approx 1 deg per second a clear indication of circulation problems.
solution GET RID OF THE FERROLI
Dec 22, 2010 | Heating & Cooling
Problem with heating on ferroli optimax 31c
d2 is the code symbol for delay after central heating. and is not a fault code.. however if this is coming on then stopping the operation of the boiler then it usually points to a sticking diverter valve.
Mar 28, 2009 | Quasar HQ2051TH Air Conditioner
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
1,902 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
