Code remote code for emerson lc200em8 need the code
Hi...Need rca universal remote code(s) for emerson tv. Can you help?
Posted on Sep 01, 2008
Need code list for Emerson TV
Kathlene, Check the attached links,instruction and guides Emerson TV codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-emerson-tvs
https://www.remotecodelist.com/remotes/emerson/emerson.html
What is the remote code for an Emerson TV
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Jun 08, 2016 | Emerson Televison & Video
Need Code for LC200EM8
Hello
Three digit remote codes for Emerson TV are:-
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit remote codes for emerson TV are:-
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Switch ON- and OFF the TV by its front panel power switch [not by the remote handset] each time before trying an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 19, 2010 | Emerson EWF2703 27" TV
We have a RCA remote and need the codes for an Emerson TV. Can you help?
The codes to program an RCA RCU300WBL remote control for an Emerson TV are:
Code 004 for Emerson TV Code 006 for Emerson TV Code 012 for Emerson TV Code 023 for Emerson TV Code 025 for Emerson TV Code 026 for Emerson TV Code 029 for Emerson TV Code 030 for Emerson TV Code 033 for Emerson TV Code 035 for Emerson TV Code 036 for Emerson TV Code 037 for Emerson TV Code 038 for Emerson TV Code 041 for Emerson TV Code 042 for Emerson TV Code 043 for Emerson TV Code 046 for Emerson TV Code 047 for Emerson TV Code 048 for Emerson TV Code 049 for Emerson TV Code 073 for Emerson TV Code 123 for Emerson TV Code 162 for Emerson TV Code 171 for Emerson TV Code 177 for Emerson TV Code 179 for Emerson TV Code 191 for Emerson TV
If you have a different RCA, remote control you can post more details, or take a look at the RCA Code Finder Website at:
http://remotefinder.rca.com/default.aspx?site=rca
Aug 08, 2009 | RCA RCU300WBL Remote Control
Need code to sanyo t.v. from emerson remote
Emerson Jumbo Remote code for Sanyo TV. 004 013 049 108 110 180 209.
Emerson Jumbo Remote code for Sanyo VCR/DVD. 042 191
Apr 21, 2009 | Emerson Televison & Video
Remote control code for Emerson LC200EM8
Have you tried the searching for your code option on the 15-2147?
for example, turn on your Emerson LC200EM8( press the appropriate key on your remote, if this is a TV.#1.press the tv key on your remote)..#2.Press and hold the little 'p' key till the LED lite,on the remote, blinks twice..#3..then enter 9 9 1.(the led should blink twice).#4.Aim and..Press the Power off on the remote....(the remote will start sending IR codes from its library to the selected device, starting with the most popular.)#5..If the TV responds go to step 6..if not, press the CH+ button, until it does...step #6 when device responds, to lock in the code, press 'p' once, the LED blinks twice.
Once you have your number locked in,,,you can get the remote to tell you what sequence the code is in by #1Press the appropriate key on the remote.(i.e, TV press the TV key ....Dvd player or VCR, then press that key). (Note: make sure you are aiming the remote at the device so the IR(infrared) enters the device.) Step #2 Press and hold the 'p' key(upper right corner of controller) until LED blinks twice, then release....Step #3 enter the code 9 9 0 ..the LED lite blinks twice. ..Step#4 to get the first number of the code press th e number 1 on the controller...the LED will blink the once for 1 //twice for 2...three times for3...etc...write down how many times the LED blinks(if it doesnt blink the first number of the code is 0) Repeat step #4 to get the remaining numbers, i.e. for the second mumber of the code enter 2...third number enter 3...till you have all four numbers.( when done you can press a different device key to get you off... then press the right device key for your device to operate it remotely. Hope this helps
Aug 31, 2008 | Radio Shack (15-2147) Remote Control
Need codes for rca universal remcon to emerson vcr and need codes for emerson vcr and coby 224 dvd
Try these codes for the emerson:
Code 003 for Emerson VCR Code 007 for Emerson VCR Code 012 for Emerson VCR Code 014 for Emerson VCR Code 015 for Emerson VCR Code 021 for Emerson VCR Code 024 for Emerson VCR Code 025 for Emerson VCR Code 026 for Emerson VCR Code 029 for Emerson VCR Code 031 for Emerson VCR Code 032 for Emerson VCR Code 033 for Emerson VCR Code 038 for Emerson VCR Code 041 for Emerson VCR Code 054 for Emerson VCR Code 065 for Emerson VCR Code 116 for Emerson VCR Code 130 for Emerson VCR
and I wasn't able to find any for the dvd player :/
Jun 13, 2008 | RCA Universal Remote Control
Code
What type of remote are you using? Thanks!
Jan 20, 2008 | Emerson EWF2703 27" TV
Remote Code for Emerson LC200EM8 LCD HDTV 20 inch
sony RM-VL600 remote, can be programmed remote to remote...I bought it, it works.
Dec 29, 2007 | Televison & Video
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
Electro Med Services...
