Question about Frigidaire GLTF1670A Front Load Washer
Loud bangs as it is washing clothes as if unbalanced, the drum is very loose
  • Frigidaire Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 26, 2010
My Samsung washer model wa456 will not spin all the way out with even just a few clothes in it and shakes really had, what do I do?
Washers have a switch which disengages the motor if the load is unbalanced. An unbalanced load will cause the drum to spin irradically and bangs against its bumpers Either you are not loading it correctly or one or more of the flexible supports that keep the drum centered, are broken or disconnected.
Feb 15, 2017 | Samsung Washing Machines
Amana top loader washing maching permanently tilted drum & loud banging during spin cycle
I guess you washed some curtains and blankets in it that it spun unbalanced. There are 2 things. One is the one of the suspension springs broke off. Another is the center post is already bent. You may have to check inside. If you are handy, you can take off the cover and check. Suspension springs are dangerous when being replaced. You may have to wear a pair of goggles. With the centerpost, it is difficult to replace. I suggest you call a technician for this.
Jan 17, 2014 | Washing Machines
Zannusi banging
It sounds like it's unbalanced. Try redistributing the clothes and/or washing smaller loads. If that doesn't fix the problem, you may need to call out a technician.
Dec 31, 2012 | Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
On wash cycle it makes a loud banging noise
Hello, The banging noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Usually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Thanks
Jun 14, 2010 | Maytag Bravos MTW6600T Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
Loud banging noises
Hi!
The reason of this noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Ussually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 06, 2009 | Washing Machines
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
136 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
