Question about Hotpoint First Edition FEW12 Front Load Washer
Washing machine making awful noise when spinning. Dont think it is bearings, washes fine, I suspect that it may be: at back of machine at the bottom, there is a pipe leading from the drum, and a removable filter thing with a ball in. Two peices of plastic, kind of like cable ties, came out of the filter. Now it does sound like a ball being tossed around in the machine, so I am wondering if these two plastic strips, are meant to be holding the ball in?
  • Hotpoint Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 26, 2010
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My washing machine is making an awful noise when its changing direction on the drum motion and changing programme. its sounds very much like some sort of ball baring has come loose. - what doi I do please...
put the machine onto drain position if it still makes the noise it is something stuck in the pump check and clear filter if makes noise only when drum turning then is highley suspect bearings have failed.
Jun 02, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
May 06, 2009 | Amana Washing Machines
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Hotpoint First Edition FEW12 Front Load Washer Logo
257 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
