Question about HP PSC 2210 All-In-One InkJet Printer
Broken part The flap that folds down over and keeps the ink cartridge in place on the color ink jet cartridge has broken. Can it be replaced? If so how would I get the part?
  • 532 Answers
It looks like this website has all kinds of HP printer parts. They also have a contact number for parts not listed.
I hope they can help you.
Here is the link.
Posted on Apr 25, 2010
Cartridge holder and flap are broken.
try holding it down with a bent paper clip, otherwise, without costly replacement parts(th moving head assembly) it isn't practical...
Dec 31, 2012 | Dell Photo All-in-One Printer 924 -...
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hi, I have the Canon Pixma MX310 and I tried to replace the ink cartridge but I messed i up and I still don't know how to replace it... I think it's error 5100 or something because it says it on...
Installing ink cartridges:
Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.Note: - Do not attempt to reattach the protective tape once you have removed it.do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  1. *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  2. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)Confirm that the ink cartridges are installed properly.OR
  3. <1> The ink cartridge is not installed properly.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
  5. Wait until the preparatory operation is complete; it takes about one to two minutes.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
Sep 24, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a dell all in one printer 944. When I turn it on it keeps sending the message, "change ink cartridge" I have changed the cartridge twice and message remains the same. Is it broken?
Are you using Dell Series 5 ink cartridges?
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message, please read bleow.
Black cartridge = black side(left side) Color cartridge = Color side(right side)
Photo Cartridge = Black side(left side) Color cartridge = Color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Rick
Jun 27, 2011 | Office Equipment & Supplies
How to change ink cartridges
for the leaser printer open the flipping hood pull the thing up from its handle with diagonal up pulling
if it is color ink jet
trun the printer on on fold the front cover the tow ink cartridge will come in front of you remove it buy pull down-back then up
May 29, 2011 | Office Equipment & Supplies
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
How to change cartrigde
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Oct 24, 2009 | Canon MX300 Office All-In-One Printer
How to change the ink in a Canon PIXMA MX310?
May 27, 2009 | Canon PIXMA MX310 All-In-One Printer
HP 6310 printer says HP 95 tricolor is empty.
Ray,
It sounds like you need to replace the cartridge with a new one. The electronics may have went out. We see this usually during the winter months when the static electricity in the air is high and we shock the cartridge. I would also NOT recommend cleaning the head/jets of the cartridge with alcohol. The electronics are fine to clean with alcohol both inside the printer and on the c artridge, but the head will dry out. We recommend taking a damp warm wet paper towel, placing it on a protected surface, and placing the head of the cartridge on the paper towel until you see some ink appear. Then put it back in your printer and let the printer clean off the bottom. If the printer is not cleaning off the bottom of the cartridge, the printer cartridge wiper on the carriage may be broken or stuck.
May 16, 2009 | HP Genuine HP 95 Tri-color Inkjet Print...
U163 keeps coming up!!
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. Confirm that the printer is powered on
  2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot**One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
8. Confirm that the ink cartridges are installed properly.
  1. Fold the scanning unit support and close the scanning unit (printer cover).
  2. Wait until the preparatory operation is complete; it takes about one to two minutes.
I hoe it helps!!!
Dec 05, 2008 | Canon PIXMA MX310 All-In-One Printer
HP PSC 2210 All-In-One InkJet Printer Logo
162 people viewed this question
Seeker5211
Seeker5211
