Question about GE JTP20 Electric Single Oven
Oven and stove not working but lights turn on
I have a rental place and my tenants said the oven and stove are not working. When they turn the dial to turn things on, the lights work but no heat is coming out. If this is a fuse or a circuit issue, can I fix it myself?
  • GE Master
  • 43,501 Answers
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
Oven light won't turn on or off with the switch
it is an electrical problem and if you do not get in a qualified technician to fix the problem it is a jail term for any one not qualified who works on, or authorizes any work by unqualified persons should any person get a shock or be killed
Jun 19, 2017 | Whirlpool GBS307PR Electric Single Oven
Electric fan oven
Sounds like the oven thermostat stuck, for whatever reason and then the oven overheat thermostat kicked in. At the very least, I think you will need a new oven thermostat and possibly an overheat one as well. On the 720 there are two, one for each oven, so when you take the oven to bits, check both out.
Dec 17, 2011 | Stoves Ovens
Elderly tenant unable to use oven as they don't know how to turn it on. elements work ok as new so what is the trick. manual not avl from owner of rental house
You have not mentioned the make model of the oven, whether it is gas or electric.
Please check for gas line, gas valve, gas regulator to open and ignite.
If electric make sure there is power at the outlet, if the circuit has tripped, check mains.
Please consult your landlord before you pull out any units as he could be the best help.
Nov 16, 2010 | Ovens
I have just moved into a flat with a stove electric oven and I can't work out what the dial symbols mean. How do I use the grill and oven etc
check your manual if you don't have one check the internet for your model and download and then print it out.
Oct 22, 2009 | Stoves 720EF Electric Double Oven
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
GE JTP20 Electric Single Oven Logo
125 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
