Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Bissell lift off stops working after falling over.
My bissell lift off fell over backwards while hoovering,upon standing the machine back up it refused to start again.I checked the plug fuse and also left it to rest for 30 minutes but nothing seems to get the machine going again.....any ideas???
    President:
  • 1,673 Answers
May have a broken cord or switch.
Posted on May 15, 2008
Re-assembling the piping on the pump of a bissell aroma pro 8910
I'm guessing you took it apart because it stopped pumping water. You shouldn't waste your time putting it back together because it still won't pump. These are the only machine my store will not work on. It is built to fail after 6-8 uses and they all fail. Replace it with a Hoover.
Aug 07, 2017 | Bissell Vacuums
Bissell lift-off deep cleaner pet will not spray solution either mounted or lifted out for upholstery use.
Sounds like either the pump quit or plugged, or if you here pump nozzles clogged. Try 2 cups of vinegar and water to help clean out
pump and nozzles. Let stand 1/2 hour, then shake it up with mixture in it, do this a few times then try and run mixture through machine
press the helpful button and follow me on Fixya for more good tips
Jan 27, 2016 | Bissell Vacuums
Hoover model U6425-920 falls backward
It sounds like the handle release lever is bad if the unit will not stand up. It's common when those units get a little older. It is unlikely you'll need the rear handle assembly (the part with the filter housing) but it does happen. Inspect the latch on the handle assembly to make sure it's not too worn to know for sure. Chances are, the handle release lever is just spent.
Here's the part you're looking for:
http://vacuummedic.com/product.php?id=171
As long as you're into it the belts and roller are always a great investment. Replacing them will make it clean like new again. I'll include the links for those parts as well.
Flat Belt:
http://vacuummedic.com/product.php?id=6
V-Belt:
http://vacuummedic.com/product.php?id=485
Brush:
http://vacuummedic.com/product.php?id=484
Happy Vacuuming!
The Vac Dr.
Dec 27, 2012 | Hoover Ultra U6430-900 WindTunnel Bagged...
My Dyson falls backward & won't stand up - what's wrong?
Hi Kay,
I'm sorry to hear you're having difficulty with your DC18. If the stabiliser doesn't seem to be locking the machine upright, I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will be useful if you can have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson DC18 all floors Bagless Upright...
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My bissell ran over the cord and stopped sucking
The belt probably broke or stretched and that is why it stopped working. Here is the belt you need:
Bissell Lift Off Belts
Feb 07, 2010 | Bissell 3750 Lift Off Bagless Upright...
Cannot push forward
sounds like tear down to me to find out whats jamed in the whells ore the belt there not much to fix there things
Jul 23, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
I have a Bissell Lift-Off Revolution upright vacuum cleaner. The dirt is sticking around the black round sponge filter which is in the upper part of the cleaner. It isn't falling into the bowl like it...
Actually, that is the purpose of that filter. These filters keep the dirt, and debris from entering the vacuum motor, making the repair cost much higher. You can rinse this filter, let it dry and use it again. That filter is also inexpensive, so that you are encouraged to replace it often, But I have included a link to your owner's manual if you need anything else.. or contact me and I will try to help more.
http://www.bissell.com/images/UserGuides/3750_905.indd.pdf
Jan 22, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
165 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
