Please can you help me, I need an Aiwa AD-WX808 Deck 1 & 2 Unite for my Aiwa tape deck or a complete new or refurbish Aiwa AD-WX808 tape deck.
We have one for sale. If you are still interested make make an offer:
uta.kamleithner-maly@boehlerstahl.at
Posted on Jun 05, 2010
You can have ours if you still need one.
Posted on May 16, 2010
Aiwa AD F660 cassette deck. Having changed the drive belts, the eject button does not now work. Hook holding the cassette door shut does not drop enough to release. How can I fix this? Thanks, Brian
Have you trapped wire or something near the hook mechanism stopping it from getting full travel when the button's pressed?
The nice people at HiFiengine have a service manual for the deck, free you just need to join.
HTH
Aiwa AD F660 Manual 3 Head Stereo Cassette Deck HiFi Engine
Jan 19, 2018 | Aiwa Audio Players & Recorders
I HAVE JUST BOUGHT TWIN CASSETTE DECK AIWA AD-WX727 ON EBAY AND TRYING TO WORK IT. BOTH CASSETTE PLAYERS ARE WORKING O.K BUT WILL NOT RECORD CAN YOU HELP. I HAVE FOLLOWED THE MANUAL BUT NO JOY.
It is often a bad idea to buy dual cassette type decks. They never work very well except for one unit I have seen which was the Sony ES model. It was not cheap at $1200 a unit. You might get it to work but the performance of these is poor even when new. Avoid dual cassette deck at all costs.
Jul 01, 2016 | Audio Players & Recorders
Aiwa model ad3100u
Marrs Communications is all you need to know about getting the right belts but putting them in is another subject.
Aug 22, 2014 | Sony CASSETTE DECK Single Dual Cassette...
Need remote codes for AIWA CX ZR 525u Cd/Tape Radio Deck 5 Disk
Hi. The carousel loading belt probably needs replacing - that's why you are "helping" it.
You could try cleaning the cd lens too if it's not selecting an reading cds.
HTH
Replacement belts and laser units are on ebay.
Nov 02, 2017 | Aiwa Audio Players & Recorders
Tape deck won't open Aiwa XR-M55
I think the main drive belt is worn and I am going to buy a new one when I find a source.
Feb 24, 2010 | Aiwa XR-M55 Shelf System
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Feb 23, 2010 | Aiwa Audio Players & Recorders
Replace capstan belts
(Unplug the unit before doing the following!)
Pull the top off (8 screws). On the back of each deck you will see a motor (silver cylinder 1.5"Diam x 1.25"Long) mounted to a removeable plate. It's kind of tricky, but... Loosen the bottom two screws securing the motor mounting plate (not the motor itself) to the rest of the deck. Then completely remove the top two screws, so the moter and plate fold away from the rest of the deck. With some care, you should be able to remove the old belt and slide the new belt over the capstan flywheel and motor pulley. Fold the motor assembly back into place and secure the screws. That should do it!
Note: I used a jeweler's screwdriver and needle-nose pliers to turn the screws on the motor mount. This is real fun with all the wires in the way, but it is possible. I Also pulled the screws on the power transformer, to move it, so I could get at one screw for deck #1.
BY THE WAY: I'm ready for new belts myself, and haven't been able to find a source, except in germany. Any ideas??????
Mar 22, 2009 | Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Apr 20, 2008 | Audio Players & Recorders
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
409 people viewed this question
 Grubhead
Grubhead
