Question about Thermador 1000 CFM Internal Ventilator Model - VTN1000Q Kitchen Hood
Thermador VTN 1000Q blower motor works on medium and high but not at full speed, low doesn't work at all
2 Suggested Answers
  • 52 Answers
SOURCE: Thermador Blower Motor Not Starting
to check capacitor disconnect power to unit. remove wires coming from the capacitor making sure to note where they were connected. Using the ohms setting on your multimeter place one lead on each of the two post. Watch carefully and if the capacitor is good your meter will spike for a second then return to zero. IF nothing happens capacitor is bad. Good luck. Kevin
Posted on Feb 01, 2008
My 2010 Dodge Avenger the blower was only working on the to low and medium prop mob up with penny work for a while to penny fell out won't work now
2009 dodge avenger blower motor works on low, medium ...
www.fixya.com/.../t21143783-2009_dodge_avenger_blower_motor_wo...
Nov 2, 2013 - 2009 dodge avenger blower motor works on low, medium low,medium high but not high. Resister has ... SOURCE: Dodge 2001 Stratus - A/C fanonly blows on High ... working. Jan 04, 2010 ' 2003 Dodge Durango ยท 1 Answer ...
Oct 29, 2015 | Dodge Cars & Trucks
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
98 buick heater stop working
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Dec 14, 2012 | 1998 Buick LeSabre
Sorry its blower
These will help.
Thanks.
Dec 07, 2012 | 2006 Kia Sportage
Heater is not working
HEATER BLOWER MOTOR
These will help.
Thanks.
Nov 28, 2012 | 1988 Honda Accord 4 Door
I got a 1994 ford ranger no A/c..the High/low med fan switch only works on high? whats the issue?
resistor.
Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 12, 2010 | 1994 Ford Ranger Supercab
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
Blower motor only works on high.what do i replace?
You need A blowe motor resistor
Any auto parts store will have it
Oct 14, 2009 | 1995 Toyota Camry
Why does blower fan speed switch lock-out off and low speed positions on 1998 chevy silverado? It stopped working altogether then I replaced a 10 amp fuse and now only medium high and high will work but,...
Sounds like you may have a bad blower motor resistor.  When they go bad, they usually wipe out all speeds except high.  But could knock out just one or two of the speeds.  It should be located near the blower motor.
Sep 10, 2009 | 1998 Chevrolet K1500
Kitchen Ranges Logo
76 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
