My takagi Jr is spewing black smoke?
I have a Takagi Jr tankless hot water heater and I noticed a black spot on the circuit board. In addition, the unit is burning so poorly that it is spewing black smoke out the vent. The fan is blowing, but not much air is blowing out the vent. Can I save this unit or should I purchase a new one?
Thank you
    Novelist:
  • 128 Answers
If you are the technical type you can take it apart and clean the burner, the thermocouple and the chamber....This may fix it. If it is the orface that needs to be cleaned, call the gas company, they will clean it for you for a small fee.
good luck,
James.
----PLEASE CLICK ON 4 THUMBS UP 4 ME----
Posted on Apr 25, 2010
Why wont takagi tk jr doesnt heat
Flowmeter.....Gas Pressure.....Ignition?
I'm not psychic.
Tk-Jr is a dependable 140-145,000 BTU 2nd Gen Unit SS Vent , <.82 EF.
Failure is a Tech Service issue and the Tech may need Factory Support from California. This is probably a pre-A.O. Smith/Takagi unit
Does the igniter spark 3 times than shut down and fan purge HE? Can you smell gas tracer (remember NG/LP is odorless w/o mercapthan in it)? Tech will need a digital Manometer for Line and Manifold Pressure Test. And a Multi-Meter Toll Free # on Unit or in Manual
Sep 07, 2014 | RTO Takagi Jr. TK-JR-N Tankless Water...
991 error code on a Takagi T-K3 Flash gas tankless water heater
Re- set code!!!!
We have a Takagi TH3 DV 540 model.Air intake got blocked with snow, condensation etc.Once we cleared that then you just have to re-set it to clear the 991. On our model there are 4 tiny buttons across the bottom (Take off front cover) to find them. of the computer board assembly bottom left corner. Push the two buttons on the right simultaneously hold for 15-20 seconds or so, then turn the Takagi off then on again- should work now!
If you have a different model then those buttons will be in the bottom left corner still but running vertically- try doing as above with the bottom two buttons. We had to go without heat and hot water for 2 days until we could get hold of someone to tell us this. We called Seneca Supply 716-852-4744. Good luck
Apr 22, 2012 | RTO Takagi T-K3 Flash Gas Tankless Water...
My Takagi T-K jr. keeps flashing an error code 21....the water turns cold and we shut it off ....wait a few...then turn it back on....works for a little then wil flash again...have replaced the pressure...
In my case, the error code 21 was caused by the failure of the vent fan to run-on after shut off (easily verified by listening to the unit). The problem was not resolved by swapping either the fan or the control unit with another heater. I talked to a local service tech who had a couple of suggestions. One was to move DIP switch #6 to the upper position. After doing thisit will be necessary to re-initialize the controll by cycling power off and on. This fixed the problem. I emailed Takagi tech support to ask if I should consider this as permanent fix, or if there was something else I should do. Since I got no reply, I'll pass on the tech's other suggestion: buy a Rinnai.
Mar 27, 2011 | RTO Takagi Jr. TK-JR-N Tankless Water...
Takagi Jr Flash Water Heater Problem
explain your problem.
Takagi is a great tankless heater, very few problems...
need more info
Aug 04, 2010 | Ultra Max Takagi Flash TH-1 Ultra High...
Tankless water heater not meeting the need
Yes the faucet could be a problem. Try changing for one which you know is ok.
The long run of pipework - each bend, elbow or joint all have a reducing effect on the flow, maybe enough to matter with a restricted outlet. none of this can be altered except by renewing with larger bore pipe - expensive!
Also there should be a dirt filter in the mains water input line/pipe. Try removing & cleaning. Try also removing , reconnecting and then the hot tap [faucet]
The boiler will have an actuator valve which fires it up when a certain flow of water is reached. If the flow is reduced AND the valve is worn, maybe a replacement. Not sure about it's USA construction but in the UK [it's called a diverter valve] many have a rubber diaphragm which is cheap to replace
Check also if it uses a flow sensor switch
Had a look at the Takagi web site and there are pdf's of manuals
takagi.com
Overall I am still thinking that the main prob is in the flow.
Hope I've helped - come back anytime
Rod.Davies
Feb 19, 2010 | RTO Takagi Jr. TK-JR-N Tankless Water...
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Takagi TK-JR vibrating noise
Remove your hydronic pump and replace the flexible impeller coupling that couples the impeller blades to the pump motor. make sure you don't do this on a sat or, sunday (i hate house calls then) and, be sure you have a new pump housing gasket before you start the job. Also check the unit for loose pipe brackets
May 20, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
