Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Light Pull chain does not pull - Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
  • stevemudrick Apr 25, 2010
    Looking for instructions on how to get to the switch and how to remove and replace it ..
  • 10,319 Answers
The pull chain switch is at fault and needs to be replaced They are sold separately through the manufacture or most hardware stores today
Posted on Apr 25, 2010
Why does my Hunter ceiling fan light not come on when I pull the chain?
did u check the light whether it is alrit. in other case check the wires may be disconnected.
Aug 26, 2014 | Hunter 52" Ceiling Fan With Light And...
The part that is attached to the pull chain inside the fan casing broke
You have to buy a new light pull chain switch. Will either have 2 or 3 wires depending on the type of light you have.
Dec 02, 2013 | Heritage Dryers
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
Hello, I currently have a celing lamp in my kitchen. There is a little cord you pull to turn it off. The onlything is, is that the cord is not working and i dont know how to turn my lamp off if not to...
The lamp has on-off pull-chain switch.
You can buy replacement pull-chain switch at hardware store.
Buy the pull-chain switch that has two wires.
Buy two yellow or orange wire nuts.
Switch off breaker.
Take apart light.
Remove old pull-chain. Strip back the wires if needed, twist wires together.
Connect new pull-chain switch using wire nuts.
Sep 22, 2011 | Electrical Supplies
Center pull chain came out the one that turns
you need to replace the switch . which is where the chain came out
Oct 31, 2009 | Hampton Bay 52 In. Polished Brass and...
Pull chain for fan difficult to operate
All Hunter ceiling fans are "remote control" adaptable. Consider a remote control for it.
There are Nylon pull strings fitted with a ball clasps on the ends. Consider that, too.
Both at Lowe's or Home Depot...
Oct 01, 2009 | Hunter 22451 The Brookline Brushed Nickel...
Cannot turn off a pull-chain fixture
It sounds like you have accidentally by-passed the switch. The switch only needs one power leg to the pull-chain switch and the other 3 wires go on the other wire of the switch. The white wires get connected together as you have done.
Please turn off the power before you make a change.
Sep 19, 2009 | Kitchen Appliances - Others
Pull chain
this is the type of switch that attaches to one wire only do you understand?if connects to live wire to break the conection.
thank you for useing fixya
Please turn off main befor fix
RATE ME
Apr 20, 2009 | Solar 2-wire Pull Chain Light Switch For...
Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Feb 13, 2008 | Heritage (5BUW52NK2YQ) 52" Ceiling Fan
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
65 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
