Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
COMMUNCATION TO DISC DRIVE FAILED
I am getting Error Code OX80020022 when trying to burn a CD with my Macbook. Please can you help
  • 22 Answers
Here is apple solution to the known problems of the disks drives.
http://docs.info.apple.com/article.html?artnum=88275
Posted on Apr 18, 2008
SOURCE:
Why does the error code ox80020022 on mac when try to burn a cd
Communication between your computer and disk drive have failed. Try a different disk. If you lower the burn speed it may help you get the job done. Put it to about 24X and see if that works.
Jun 23, 2014 | Apple MacBook Air
ERROR 2131 WHEN ON ITUNES
According to the support page the firmware update fixes the iTunes
issue with “The attempt to burn a disc failed. An unknown error
occurred (2131) when you tried to burn playlist to disc for blank CD-R
media. the region code error for DVD movie playback.
NOTE Please DO NOT USE THIS UPDATE FOR A TOSHIBA LAPTOP the computers
may have the same optical drive but the firmware updates may not be
identical and flashing with the wrong firmware may damage your drive”.
This isn’t just the Toshiba Equium A200 laptop getting an error of
2131, the other notebook’s manufacturers also established the source
of the problem and they have to provide a firmware update to download
and fix this problem. The best thing you can do is wait until Toshiba
provide a firmware update specifically for the TSST TS-L632H version
TO01 drive in your laptop.
Please let me know if you have any fuhrer questions or concerns.
Thanks.
Apr 25, 2010 | Toshiba Satellite Pro L300 Notebook
Cannot write cd/dvds.
The Super Drive needs to be replaced. This error cannot be fixed with software.
If it's still under warranty simply take to an Apple Store, Apple Authorized Service Provider, or contact Apple at 1-800-APL-CARE (1-800-275-2273) or contact an Apple Expert at http://www.apple.com/support/expert/
-=/ Daft Tech /=-
Oct 22, 2009 | Apple MacBook Pro Notebook
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
Aug 13, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Open Questions:
Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]
Oct 15, 2019 | Computers & Internet
See all Apple MacBook 13"White /2.0Ghz Intel Core2 Duo Questions
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
635 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
