Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a troy built horse rear tine tiller serial # has faded away, question is how do i change the drive belts? engine is on a carrige and slides up and down to engage belts [two short belts] there is not enough room to remove old belts and slide in new ones, engine bolts are behind pulley there must be an easy way to get the belts on and off. there is a casting # TH1o19 on handle upright thank you for any help
  • 23 Answers
If it has the reverse fiber disk on it. Take it off 1st and it will allow the engine to go down farther. Most of the time if you take the pully bolt from the engine out the pulley will come of when you pull out on the housing. You must remove the slide pins for this to happen though. There are set bolts on the side to remove the slide pins. It is still a little tuff to get the belts in and make sure they go inside the belt guides on both sides. I just take 1 slide pin out of mine and swing it out a little to put mine on.
Posted on Jul 04, 2010
Adjustment for belt for 8 horse power horse. Really need to find a manual. Where can I locate one?
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/21A682J766/Troy-Bilt%208%20HP%20Rear%20Tine%20Tiller%208%20HP%20680%20Series%20Briggs%20and%20Stratton%20Engine%20Manual/275092/
May 29, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Drive belt is slipping when under load. How do you tighten the belt. thanks, Ted Troybilt Horse rear tine tiller
hi there, ive been doing a bit of head scratching over this one as i needed to check my facts. i think the belt has a automatic spring loaded adjuster so it sounds as if you need a new belt for it.
good luck
iain
Apr 30, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I am currently looking at buying a troybilt horse with serial # 340455. Can someone let me know what year this is?
That tiller was made sometime between 7/1/78 and 1/1/79. This is the Horse II model and is a four speed one belt tiller. The Horse I was a two speed two belt tiller. These are very good tillers if they have been reasonably taken care of.
Frank
Sep 30, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Hi! i have older troybilt rear tine tiller and would like tires and if possible a owners manuel the only serial # i could find is 464932. do you have access to older parts for equipment such as mine?...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to the above website and put in your model and serial number. If it is a Horse tiller just type in Horse and your serial number and you can download a copy of your operator manual. If it is the Horse model it was built between 1/1/80 and 7/1/80. i believe you have a Horse II four speed model that will just have one drive belt the older Horse I tillers were two speed with two belts.
Most any good tire shop can supply tires for your tiller or you can order them online and take then to a shop to mount for you. If your tires are not real bad they can just put tubes in them so they will hold air. Almost all parts are available through MTD who owns the Troy Bilt name now or through many sites online.
Good Luck,
Frank
Aug 11, 2010 | Troy-Bilt Garden
How does the gear box come apart on a six horse troy built tiller?
  1. Remove belt guard on left side
  2. Remove belt, large pulley on gearbox.
  3. Remove throttle cable, idler pulley cable and shift handle.
  4. Remove engine, handle, wheels, tines cover and tines.
  5. Lay gearbox on side on two sawhorses, left side facing up
  6. Remove all the nuts on that side. If the three shafts have corrosion, use sandpaper to remove.
  7. Pry the two halves apart, then hammer the ends of the three shafts to push through their bushings. Use brass or wood to avoid blossoming the shaft ends. When shafts are through their bushings, the right side will fall away.
Jan 15, 2010 | Troy-Bilt Pony Garden Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I need a new motor for horse model, serial no. 360331. which models fit this troy built.
Just about any engine with a 3/4" horizontal shaft that is internally threaded on the end and has the four bolt mounting pattern around the shaft will work. I have gone to Harbor Freight and purchased their 6.5 H.P. engine that is a Honda clone and it will work fine and only costs $100-150 dollars. The only difference is that it uses a metric bolt to hold the pulley on the shaft,the four mounting bolts are metric and you have to disconnect the low oil shutoff or the engine will die when you are tilling deep. It is a good low cost option for the Horse tillers.
Frank
Jun 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
May 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
200 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
