Question about Troy Bilt Tb70ss Gas Trimmer
How do you remove the Troy Bilt TB75ss head/outer spool?
5 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Posted on Jun 10, 2009
rycgl
  • 1545 Answers
SOURCE: How do I remove the
The Troy Bilt spool should be able to be removed by pressing it down and twisting it.
Posted on Aug 08, 2010
SOURCE: how do i remove the
If you are talking about the side where the clutch is, there is a Torx screw inside the hollow part of the clutch housing. Using a #20 Torx bit, loosen screw. If this is the first time on this screw it will be tight and the drive shaft will turn with it. You will have to remove top of cylinder head and put something soft inside the cylinder to stop piston from moving up and down; usually a towel and something stiff like a screwdriver to hold it from moving.
After clutch housing is removed, the clutch itself is threaded and by holding the shaft with pliers you can unscrew the clutch.
Past this, just screws holding the plastic housing.
Posted on Nov 28, 2010
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
How do you remove the head on a troy bilt curved shaft trimmer? Tb539e model
It depends on the style of feed head you have.
There should be 2 plastic clips that you push in, on the side of the spool, you then pull the cap cover off.
OR you have to unscrew the dump cap on the spool..
Apr 27, 2016 | Troy Garden
How do I remove the trimmer head from my TB32EC Troy Bilt trimmer to clear grass build up inside of plastic head?
Depending on the style of head, you either unscrew the cap on the end. of you push 2 clips in and pull the spool cover off.
Jul 14, 2015 | Troy Garden
I am trying to remove the outer spool assembly. How do I do it?
What does it say in the user manual? Or possibly you don't have one and haven't gone online to get one.
Anyway, most of these spools are removed by pushing two lugs together while pulling the spool away from the housing. Replacement is by just positioning the spool and pushing it into the housing until it clicks into place.
Jun 29, 2015 | Troy Bilt Tb70ss Gas Trimmer
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
I am trying to replace the head on my TB575EC trimmer but can't remove the black inner spool. Any suggestions?
Unscrew the head's center bump-knob counterclockwise with your fingers. Pull the bump knob off and take the spool cover off the head. Slide out the spool and any remaining cutting line. Lift out the spring underneath the spool. Take out the slide washer. Unscrew the arbor bolt either clockwise or counterclockwise, depending on model, in the center of the trimmer head using the wrench. Take the entire head off the end of the shaft.
Sep 03, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Sep 07, 2009 | Garden
Can not remove troy bilt weedeater head
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Jun 07, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt Tb70ss Gas Trimmer Logo
613 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
