Question about GE Refrigerators
Click click click repeatively - lights and digitals flash every time it clicks. GE Profile PDS22SFSBLSS
  • 1,543 Answers
Replace the motherboard, part number WR55X10942
It is easy to replace, from behind the refrigerator.
Posted on Apr 25, 2010
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
The refrigerator temp lights are flashing on and off and its making a clicking noise..ge profile refrig with freezer on bottom. I unplugged for 5 minutes and replugged with no help
your main-board/motherboard is bad,a telltale sign is,if just recently had light bulbs burn out in the refrige compartment and now they strobe dimly and the digital temp readout is also out and you sometimes hear relays clicking back there, the board took a voltage surge and ruined the circuit trace,replacement is simple,unplug 3 harnesses and snap in new board and plug in new board and youre good to go
Feb 22, 2010 | Refrigerators
Ge refrigerator
HI. This will be the cause of a defective PCB. This circuit board is the main controller of your unit. the clicking is the result of a failed relay assembly. these relays are mounted on the board, itself. The board should be mounted just behind an access panel, on the rear of the unit, slightly above or near the compressor assembly. Kindly have this PCB replaced, asap.
The PCB is , indeed, the culprit in this situation. Once the PCB is exposed, you should visually inspect for brownish discoloring, and relay trauma. Possible power surge may have caused the board to short.
Feb 01, 2010 | GE Profile Stainless Bottom-Freezer...
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile WPGT9150 will not start cycle
You have a bad transmition.
Please rate this solution
Aug 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Not cooling at all
refridgerator not cooling making clicking noise from back
May 03, 2009 | GE Profile Stainless Bottom-Freezer...
Ge side by side not cooling
Unplug refrigerator and remove panel on back to expose the control board. Look for burns or smell of burned board. Look at both sides and let me know if you see any problem, Thanks, Sea Breeze
Mar 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Sep 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge Profile dispenser panel
Here is a link that will help give you a step by step process of elimination, click below and insure you have the correct model numbers as you move through the process, Thanks Sea Breeze
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Oct 26, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
263 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
