Question about JVC KD-SHX701 CD Player
Jvc 701 exad how to tune radio in
No instuctions
The touch screen problems.malfunction.touch screen lost function even touch.model no exad kw avx-800
if the screen gets wet it will corrode at the data wire and not pick up a signal
Jun 28, 2011 | JVC KW-AVX800 CD Player
Why dont my jvc exad eject when i press the button
try disconnecting power to the radio overnight and reconnecting it in the morning.
Jun 12, 2009 | Car Audio & Video
I can not tune on even fraquencies
Thats USA tuning, you can only get those odd stations on that deck.
May 30, 2009 | JVC KD-S5050 CD Player
What colour are the power wires, are they green & yellow, black, black & grey, blue & grey, red & grey or black & green. I want to connect a cd/radio player but don't know what wires connect to the cd...
JVC KW-AVX800 The black wire is your ground The yellow is your positive 12v constant so connect this to the wire that has 12v when the car is off. The red connect this to the key switch wire meaning the wire will have a 12v signal only when the key is tured to the on position. The blue is for a power antenna the blue/white stripe is if you have external amps this wire goes to the amps remote on The orange/white stripe connect this wire to your cars dimmer switch Happy Wiring
Mar 21, 2009 | JVC KW-AVX800 CD Player
Trying to download a manual for a JVC car radio KD-DB711
Go to http://www.dabonwheels.co.uk/JVC_KD-DB711_DAB_car_radio.html
Scroll down to near the bottom of the page and you will see a square box on the right hand side, with view instuction manual.
Select it and then the whole manual will be shown for free. You then just hit print and you have it.
Cheers,
Grant.
Nov 13, 2008 | Car Audio & Video
Tuning the JVC radio
Hi, it depends were you got the radio from mine is doing the same its a grey product and comes from US or other countries.If you are lucky just hold and press the setup key for +- 5 seconds and it will jump to setting HH then press the + or - button were you change the radio, go to area and turn knop on radio to US or other country thats working for you. Hope it helps
Nov 11, 2008 | JVC AM FM CD DET FACE CAR STEREO
EXAD KD - AR5000 Programming
Do you also lose your clock and radio station presets?
Nov 08, 2007 | JVC Arsenal KD-AR5000 CD Player
Jvc exad model kd-avx2
You'll have to connect the wire "parking brake" at the back of the JVC to your ground wire (black)!
Nov 08, 2007 | Car Audio & Video
JVC KD-SHX701 CD Player Logo
118 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
