Question about Kenmore 24 in. 16472 / 16474 / 16479 Built-in Dishwasher
We replaced the heating element and control board
We replaced the heating element and control board in our Kenmore 16479 dishwasher. After two successful cycles, we now have no power to the LED and the dishwasher will not start. Any suggestions?
Thanks,
Paul
    President:
  • 949 Answers
Hi Paul,
First off check to make sure you have incoming power, that the circuit breaker is not tripped or fuse blown, the outlet it is connected to has power, no switch that controls that is off.
If power is going to the dishwasher the most common reason for the unit to be dead like this would be the thermal fuse. The thermal fuse is a device that clips on to the control board you just replaced. It senses the temperature of the board and trips if it gets too hot. My guess is that it either is not clipped on to the new board in the right spot or one of the wire connections to the board or this fuse is not tight and creating enough heat to trip it.
You will need to replace this fuse if it is bad, it will come with new wires for it. Be sure to install the new wires, the kit will have instructions.
Posted on Apr 25, 2010
Ultra wash Kenmore dishwasher. Does not matter what wash cycle you choose it pauses I think to heat the water. It never gets past the wash and does not shut off. If the element is bad can I tell without...
In many cases the problem is in the Circuit board. The controller board usually becomes defective prior to the hardware being defective. Only a service technician can do a test of the system and he has the ability to replace the board if necessary.
Jan 11, 2018 | Dishwashers
Kenmore dishwasher 665.16539201 heating element wires came off. which go onto which terminal
Check and click this link for tips: Front panel
Now check the voltage to the heating element from the control panel and if this is present the element has failed.
If not the control board is a suspect. check the wiring harness and connectors.
Jan 23, 2013 | Dishwashers
Model #66516352301 replace heating element
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 06, 2011 | Kenmore Dishwashers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dishwasher won't run. Replaced door latch and timer/selector unit. Into this POS for over 200 bucks right now, with nil result. Any other ideas? Clean light comes on so power is getting through it.
If it's KitchenAid or Whirlpool or Kenmore, and your clean light BLINKS and the heating element inside is ROUND - there is a problem with your control board and the element. There is a kit containing both, for the price of the heating element alone.
This might be the part you need
Oct 14, 2009 | Dishwashers
Dishwasher blinking clean light
replaced control board with heater & t,stat
Jul 14, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 16602 dishwasher
Exactly, if the heater is not defective, please do not replace it. I am aware that the owners manual says that if you have the clean light to flash then the heating element may be defective. More times than not the heating element is not defective but the controls can be reset and you can send the unit through a diagnostic test to find out what may be defective.
Mar 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher isn't heating and dishes are always still wet at end of cycle
hi,
could be a few things, control board, heating element, sensors. look at the heating element, (the thin dark tube under the bottom rack) if it looks broken or caked up with calcium it may need to be replaced. if it looks ok start the wash cycle and let it run for a minute, then open the door and tap it very lightly and quickly with your finger to see if it's getting warm, if it’s not hot it could be a board/wiring/sensor problem. , if it’s in warranty contact the manufacturer if not contact a sears or a local appliance repair company
Mar 16, 2008 | Kenmore 15121 Built-in Dishwasher
Kenmore 24 in. 16472 / 16474 / 16479 Built-in Dishwasher Logo
143 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
