Question about Casio GShock Illuminator watch
How to change time
How do you change the time
  • 2,334 Answers
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
Posted on Apr 25, 2010
Date does not change after 12:00 am
Does it change at all? You may just have to set the time 12 hours later so it changes at midnight not lunch time
Nov 30, 2013 | Neff Flava White Digital Watch
Change time
Advance the time by 23 hours. And reset the day to the correct one. make sure that the date change occurs at midnight your time and not at noon.
Nov 07, 2013 | Swarovski Authentic Crystalline White...
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
Hi jessestaton,
All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
In case you have any queries, feel free to get back.
Hope this helps ..:)
Jun 12, 2011 | Watches
How do i change the date on my tag heuer formula 1? i know how to change the time. I went to change the time and in doing so it changed the date. when i went backwards it would not change back
You change the date the same way you change the time. The only difference being pull the crown out 1/2 way to the first click instead of all the way out.
Oct 19, 2010 | Tag Heuer Formula One
Cannot change the time on my watch
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file
May 07, 2010 | Watches
Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Feb 08, 2010 | Fossil Fuel Josh JR9120 Watch
Need to change to Daylight savings time- automatic change did not happen
I need to change the current time. It does not change with daylight savings time, and I always have a problem setting it. Can you help me?
Nov 01, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Casio watch 3793 cannot change time
the best you can do follow these steps:
lests say
the top left button is a
the lower left button is b
the light button is c
and the lower right is d
to change digital time, when in time/date mode hold a untill seconds start flashing. then you can change the seconds. hit d do change seconds.
then you hit b wich brings yyou to Daylight savings, change with d
then hit b to change to hours, you can go up and down digits with d and C(LIGHT) then hit b to minutes and so on.
then hit a once to confirm and again to toggle from date to time
for analog time changing:
in time mode press a six times until it says: "h-s"
then hold a until the display flashes then press d for every minute you want to skip, you can also hold d and then press c it automaticly starts changing then hit d to stop(and maybe correct with a couple of "d's"
hit a to confirm.
there you go
Oct 26, 2008 | Casio Casual Sports Watch HDC6007BVCF
Casio GShock Illuminator watch Logo
153 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
