Question about Ardisam 5.5 Hp Rear Tine Rototiller
Craftsman rear tine tiller jumps out of gear
This tiller is only 5 years old does not have 30 hours on it. Tiller jumps out of gear when tilling. Can any one help?
Thanks
boscia
  • 163 Answers
SOURCE: older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Posted on Nov 30, 2008
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
  • 10865 Answers
SOURCE: Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Posted on Apr 25, 2009
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Posted on May 26, 2009
  • 376 Answers
SOURCE: which small ''mini'' tiller to purchase
Definitely stay away from Ryobi, Troy Bilt, Bolens and Yard Machines by MTD. They are all Ryobi with different brand names on them. (goes for trimmers too) MTD owns them all. The best small tiller, IMHO, is Mantis. (2-cycle) I think Sears sells them now. I have one and it will run circles around the rest.
Posted on Jun 14, 2009
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
I have a craftsman 17" 5.5 rear tine tiller chain
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.
R.G.S.
Mar 22, 2011 | Craftsman Garden
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
Put tiller in till gear, goes fine for 30 sec and jump out of gear. tine stop. How do i fix it
Try adjusting the linkage or the shifter cable. If its too tight that will happen. I have almost the same one you do. Look at your manual and check out the blow up diagram. there is a way to adjust most models. If not you may need to replace the cable. But...before you do that make sure your cable isn't meeting with resistance somewhere causing it to be too tight.
May 04, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Aug 12, 2009 | Craftsman Rear Mount Tiller
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Ardisam 5.5 Hp Rear Tine Rototiller Logo
284 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Shehu Pro
Shehu Pro
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
