Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint aqxxd169 the dial display on my washing machine is not showing after a power cut
Take the top of the washing machine with the 2 screws on the back pull the top backwards. keep the power or ull get electrucated now ull see white plugs just simply press them in or if that doesnt work try
and click the circuit board back in
hope this helps u out
darren
Posted on Mar 25, 2008
SOURCE:
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
Hotpoint Aqualtis 2 months old dial turns without changing the display
machine is under warranty, contact Hotpoint for a service call.
Oct 15, 2012 | Hotpoint Washing Machines
Hotpoint Aquarius WMAL641 Washing Machine programming dial
see the cause:To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
God bless you
Sep 19, 2012 | Hotpoint Washing Machines
I have a hotpoint washing machine model wt746 1400 spin speed. the display shows a single red light and twiddling dials and pushing buttons does not affect the display. The machine doesn't work at...
Unplug your washer for 10 minutes, consult your users manual while waiting, then plug it back in, Still unresponsive, contact an authorized service tech.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 26, 2017 | Hotpoint Washing Machines
My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Nov 15, 2009 | Washing Machines
Hotpoint aqualtis aqxxd169 washing machine will not drain or spin
The m/c will not normally spin if there is a lot of water in it.
You need to check the pump to see if it is working o/k, and check the filter also.
The filter is located behind the bottom kick strip at the front.
Undo screws ,remove strip and unscrew the pump cover anti- clockwiwse to remove, be care ful as there will be some water run out.Clean filter and try again.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Washing Machines
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
150 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
