Question about RCA P52926 52" Rear Projection Television
Mitsubishi 4544 picture is green
    Sergeant:
    Champion:
  • 241 Answers
HOW OLD IS THE TV ?? IF IS OLDER THAN FIVE YEARS THE PROYECTION BULBS MAY NEED TO BE REFILLED AND CLEANED BY A PROFESSIONAL TECH
Posted on Apr 03, 2008
SOURCE:
Dvd to vs 4544 hook up
Download the user manuals for both devices from net. You will get all wiring data from them.
May 29, 2012 | Mitsubishi Televison & Video
How do I hook up a dvd player to vs 4544?
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
May 29, 2012 | Mitsubishi VS-4544 45" TV
Need Horiz button help on Mitsubishi 45" TV...easy fix?
No,require new main video backlight board,and vertical/horizontal stablelizer board also.Both boards alone cost u about $500 bucks not uncluding labors yet.
Oct 20, 2009 | Mitsubishi VS-4544 45" TV
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Power problems
 high voltage regulation problem. need tech service.
Nov 23, 2008 | Mitsubishi VS-4544 45" TV
Mitusbushi VS-4544 Horizontal lines then looses picture.
I'll take a guess here that the lines are at a slight angle. I believe that these are "retrace" lines and are an indication that the flyback transformer is starting to fail. The vertical IC would cause a collapse of the picture and bad caps in the circuit would effect the linearity of the picture. You can check for poor solder joints as they could cause any nunber of symptoms.
Keep us posted.
Dan
Jul 14, 2008 | Mitsubishi VS-4544 45" TV
Have sound but no picture
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Jul 07, 2007 | Mitsubishi VS-4544 45" TV
How to fix the video power supply for mit VS-4544 ?
Let me preface what I'm about to suggest with my own comments. I've been a TV Technician for more than 20 years. That said, you don't fix it without calling repairman or you wouldn't have posted here. In this unit there are common lytic caps that should be replaced without question. By location number and value they are: C979 2.2uf/200v C531 2.2uf/160v C551 2.2uf/160v C981 22uf/50v C402 47uf/35v Next it might be a good idea to ESR test other caps in the B+ line. ESR stands for (equivalent series resistance) It's a way of measuring the cap's effectiveness in a circuit. There are testers on the market for just under $200.00 for the backyard technician and they are a must. Check the set for ring cracked solder joints. The symptom of leaving it off for awhile and then being able to get a picture suggests that it could be ring cracked in one or more areas, usually areas of high heat. When all else fails there is calling the repairman. If you don't know how to find a reputable shop in your area I might suggest contacting NESDA (National Electronic Service Dealers Assn.) who can give you some reputable shop contacts in your area. Good Luck! Bill
Jun 02, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Tv wont come on
Sounds like the Horizontal Output Transistor shorted. TVs are dangerous to work on if you are not trained. The transistor can be checked easily with a dmm. If it is bad the flyback should probably be replaced too. If it is ok, you have a short somewhere else and need to isolate systems until the fuses quit blowing or hook it up to a variac and do checking to see where the short is. My bet is on the HOT. Again, if you are not qualified have a professional look at it. Good luck.
Jun 19, 2006 | Mitsubishi VS-4544 45" TV
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
